Replacement lower lift arms.
/ Replacement lower lift arms. #1
MudMixer
Mahindra 2538
Does anyone know of a cheaper replacement for the lower lift arms of the 3 point hitch on a 2538 other than the Mahindra factory parts? The Mahindra parts cost over $300 just for one lift arm!
You are probably wondering why I need the arms replaced. I bought the tractor used with about 250 hours on it. Most of the tractor is in great shape but the previous owner used it for snow removal/salting. I removed the back hoe to find the bearings in the lower arms completely rusted and seized up. I tried just a out everything to get them to break free.
/ Replacement lower lift arms. #2
I would work at them with whatever different penetrants etc to free them up, including a torch if you can safely use it in the area. If they are totally useless you might get a PRO welder to cut off the old swivel eyes and weld new ones on - the weldable ends aren't very expensive just be sure to have a competent welder do the welding if you can't.
/ Replacement lower lift arms. #3
Do you think you can install one of these at a cost of around 170.00 from Agri Supply. Could be a better option than replacing or rebuilding the arms.
Pat's 3-Point Quick Change Hitch - Category 1 With Stabilizer Bar
/ Replacement lower lift arms. #4
A friend brought a pair of lower lift arms to me for help. All four of the swivel eyes were rusted up and would not move. I put a large bar - 1 1/8" diameter - in my vice and slipped on one eye. Continuous pulling/pushing - WD40 - torch heat. Once we got it broken free and moving - it was just a matter of time and continued pushing/pulling. It took around four hours and a few beers but we got all four broken free and cleaned up.
I lube all four of my swivel eyes twice a year. Completely remove > swivel the eye so nasty black grease is applied to the entire eye surface. Reposition the eye into its normal position - wipe down to remove all external grease.
/ Replacement lower lift arms. #5
I bent mine when using the backhoe. They somehow came unhooked and I backed up…$500 later for two😭
/ Replacement lower lift arms. #7
Necro thread, but I figured this might help others.
I bought 2 of these, bolted right up and work great.
Maybe an inch shorter than factory, but $95, so yeah. Of course I replaced both, but even at $190, better than factory at $425 for 1
/ Replacement lower lift arms. #8
If they are straight still you can have the ends cut off and new ends welded on.
Truck Bumper (A62177)
48x4 Mini Skid Trencher (A63118)
48x4 Mini Skid...
2005 Blue Bird BB Handicap Bus, VIN # 1BAKBCKA45F219634 (A61165)
2005 Blue Bird BB...
2014 Ford Escape SUV (A61569)
2014 Ford Escape...
2012 Sun Coast Trailers 712ESB5 S/A Enclosed Trailer (A61569)
2012 Sun Coast...
2000 Ford F-250 (A62177)
2000 Ford F-250...
