Tecumseh 10 HP air filter
/ Tecumseh 10 HP air filter #1
JD4102004
Old Town, Maine, USA
John Deere 5103, John Deere 410 Backhoe Loader, John Deere 350 Dozer, Kubota L3400, MF 205 Industrial, L2850 Kubota, AC B, AC G, International 364 Diesel, International B414 Gas
I have a good 10 HP Tecumseh snow blower engine that I want to put on a Chipper. The snow blower motors have no air filter on them so I want to add one to keep dust and dirt out.. Does anybody know what will fit from another model? May need to do some adapting? Also the cooling air from the motor fan blows onto the carb. Will this be a problem? Probably will not use it if temp is over 70 degrees.
/ Tecumseh 10 HP air filter #2
Can you post a photo of the engine and the covering over the carb.
I think that some of the B&S lawn mower engines have a filter bracket that bolts to the carb.
Richard
Richard
They won't fit. My friend who works on small engines has lots of used parts and we checked.
I found one today that I can make work with a little modification.
/ Tecumseh 10 HP air filter #6
OK great. After you get it installed, post a photo. We all like to see what other people are doing.
Richard
Great, looks good.
Nice work.
Wish I could have put the cover on the filter but not enough room because of the throttle lever. I guess for what little I'll be using it I can replace the filter when it gets dirty.
Not even room for that. Only clears the throttle by 1/16 of an inch.
Woods Brushbull 60 3Pt Mower (A66285)
Woods Brushbull 60...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
HAMM H12i ROLLER (A65053)
HAMM H12i ROLLER...
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
