Tecumseh 10 HP air filter
   / Tecumseh 10 HP air filter #1
JD4102004
Old Town, Maine, USA
John Deere 5103, John Deere 410 Backhoe Loader, John Deere 350 Dozer, Kubota L3400, MF 205 Industrial, L2850 Kubota, AC B, AC G, International 364 Diesel, International B414 Gas
I have a good 10 HP Tecumseh snow blower engine that I want to put on a Chipper. The snow blower motors have no air filter on them so I want to add one to keep dust and dirt out.. Does anybody know what will fit from another model? May need to do some adapting? Also the cooling air from the motor fan blows onto the carb. Will this be a problem? Probably will not use it if temp is over 70 degrees.
   / Tecumseh 10 HP air filter #2
Can you post a photo of the engine and the covering over the carb.
I think that some of the B&S lawn mower engines have a filter bracket that bolts to the carb.
Richard
Richard
They won't fit. My friend who works on small engines has lots of used parts and we checked.
   / Tecumseh 10 HP air filter #4
Well you may have to get creative.
Drill, saw, cut.
I found one today that I can make work with a little modification.
   / Tecumseh 10 HP air filter #6
OK great. After you get it installed, post a photo. We all like to see what other people are doing.
Richard
Great, looks good.
Nice work.
Wish I could have put the cover on the filter but not enough room because of the throttle lever. I guess for what little I'll be using it I can replace the filter when it gets dirty.
   / Tecumseh 10 HP air filter #10
You could put one of those foam dust covers on it.
24008 (A53422)
24008 (A53422)
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2022 Coras Predator Steel End Dump Trailer (A55314)
2022 Coras...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2024 Schulte 5026 Batwing Rotary Cutter (A55314)
2024 Schulte 5026...
