Interesting attachment
/ Interesting attachment #1
Tchamp
Baldwin Georgia
Power trac PT-2422
Has anyone used or had experience using the Lane shark bush hog? It has caught my attention and I’m thinking it would be a good match for the PT line up. See photo attached
It can be turned out and angled to mow ditches or the banks of the pond or creek. It can be turned up on its side to trim branches in a vertical cut.
Very interesting.
/ Interesting attachment #2
Indeed interesting. Kinda like the boom mower attachment, but with a more rigid connection?
There are several videos on YouTube but I have not the knowledge of how to import them lol
/ Interesting attachment #4
I've seen a couple of these, but not operated one. I do a lot of the work this thing is made for and I haven't seen a place in my lineup for it.
Two things :
There's a lot of linkages to bend and the height of work necessitates some polycarbonate between the tool and operator
A power pole saw and a chipper will leave a better looking, longer lasting lane or field margin. This type of mowing, particularly of trees induces aggressive regrowth.
Two things :
Hmmmm good thoughts, thanks. I was thinking it would be good for setting up a deer stand in the woods for a clear firing line or to trim my long driveway, walking paths in the woods etc. making a quick work instead of a longer couple days. Just one afternoon mowing out a lane then cleaning up the middle. There are wild blackberries all over where I am from but can’t get to them, this would be a good tool to cut small paths to and through them, not too wide but just enough to be able to navigate without getting tore up by all the briers and underbrush
/ Interesting attachment #6
The pt brush mower or a hydraulic converted flail mower will destroy the blackberry patch.
Other than blackberries... If you trim trees back at the trunk or major branch they will take a long time to regenerate in the space you just cleared. If you mow the ends of lesser branches the tree will re-take the space rapidly. Basically because the plumbing is left in tact.
From my point of view there's a large expense for the tool then repeated margin mowing frequently.
The polesaw/chipper method is larger time outlay upfront, but less cost and longer lasting effect.
/ Interesting attachment #7
/ Interesting attachment #8
Ag I almost agreed with you until you brought up blackberries. Blackberries are tubers and love nothing more than getting dug up or chopped up. In our area you see people thinking the Tita tiller will set blackberries back and then have the patch get many times worse. Only real solution is better living through chemistry and a dose of crossbow in the fall or spring.
/ Interesting attachment #9
Didn't mean to imply that the blackberries won't come back. My point about them was lane shark does nothing the less costly pt mower won't accomplish.
But pulverize an unruly patch w a brush mower and it's mowable in the future... And no longer a thicket.
Agreed chemistry or shading it out w over story growth is the way to slow them down.
/ Interesting attachment #10
I find the PT brush cutter to be very good.
A couple thing's I'd worry about with the lane shark.
Side weight if you're using it offset on, say, a ditch.
With the PT design, to mow down into a ditch, you approach the ditch at a perpendicular angle. You're 90 degrees to the ditch. Now you could drive too close to the ditch, the ditch bank could collapse, etc., and you may go nose-first into the ditch, but you probably won't roll over.
You could do the same with the lane shark, so that aspect is a wash.
However, you'd be tempted to drive parallel to the ditch with the lane shark offset to one side, and that's where I'd be leery. You get a tire over the edge of a ditch while parallel to it and over you go.
Just my thoughts on that.
/ Interesting attachment #11
I definitely see the weight of the 425 as a problem matched to lane shark.
/ Interesting attachment #12
I agree. The LS-2 specifies a minimum 2,000lbs, which is quite a bit more than the 1400lbs for the 425.
For @Tchamp's intended use, I would lean toward brush hogging the paths a bit wider and let the branches flop back in to get the alleyway that you want, but I recognize that that is having a hammer and thinking the problem is a nail...
I could see the advantages for trimming trail edges as hedges. Charlie Iliff used to do something similar with a sickle bar cutter he put on his PT (1845?) to cut trail sides for horseback riding. A sickle bar mower is much lighter, but granted it can't do thick branches.
I think that the Lane-Shark is an interesting design, mechanically, with a rotation point and a second hinge. I had been contemplating offsetting my trencher, and this looks like a stiffer way to generate the offset.
All the best,
Peter
/ Interesting attachment #13
Perhaps himalayan blackberries (invasive in northern California and probably elsewhere) are different, but I can almost entirely eliminate them by scraping a bramble aside (burn or let be to decompose), which will often pull up some of the root nodules, and then to a modicum of pulling more roots and they're basically eliminated (I get a stray shoot here and there, trivial to manage). No poisons involved.
Given the fact that the neighbors have many brambles (which we happily harvest for jam & wine), it's pretty much impossible to permanently eliminate them (thanks, birds!) but yanking the stray new growth isn't tough.
All the best,
Peter
I have a 2425 with the backhoe attachment and i weigh just over 2100 lbs.
They don’t recommend me utilizing the attachment.
I just wanted the brush hog because it will run on 5 gpm up to 8.5 gpm, and cut up to 3 inch diameter.
/ Interesting attachment #16
Sorry to hear it. Based on other's comments on the PT brush hog, I think that you could do a lot. I know the 1445 brush hog version is a monster feared by all standing in its' path.:)
I still think it is an interesting attachment; thanks for sharing it.
All the best, Peter
/ Interesting attachment #17
Did they say why they didn’t recommend it?
There are other companies that build basically the same thing, one could look at if so inclined
/ Interesting attachment #18
I'm gonna guess because of the weight, the possible torque put on the FEL arms if it's extended to the side, and maybe the hydraulic flow and cooling(but that seems within specs).
They said becuase of the narro w wheelbase and the articulation of the unit not from the steering but for the traversing would make it unstable. I just wanted the deck for brush hogging becuase it could the 3 inch in diameter
/ Interesting attachment #20
Well, it says it will do 3" diameter, but does it say of what? I know the 48" brush hog from PT that I have will do severe damage to brush and shrubs and small trees. 2" oak takes a little finesse to get it over then chopped up. I wouldn't attempt 3" diameter anything with it unless it was dead and rotting on the forest floor.
2025 48in Rotary Brush Cutter Mini Skid Steer Attachment (A66734)
2025 48in Rotary...
2020 MACK GRANITE DUMPTRUCK (A67714)
2020 MACK GRANITE...
2019 KOHLER 38RCL Generator DISCONNECT ATS 38KW 315 HORS (A66734)
2019 KOHLER 38RCL...
2013 Volkswagen Passat Sedan (A66738)
2013 Volkswagen...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
