goeduck
Super Star Member
Sounds like grocery getter pickups for now vs long trip towing vehicles. Nothing wrong with getting groceries.
50+ years ago there was talk of using a flywheel method to power city buses. They come in handy on a hay baler with a small tractor as well.The charging stations could have local power storage. I read an article not long ago about using flywheels to store energy. A big flywheel can store an impressive amount of power, and release it quickly for a 20 minute charge. Then it could gradually spin up again, stabilizing the load on the grid.
What are you, an electrician or something ?250,000 to 350000 watts chargers. holy crap, how is the power grid supposed to support this.
Time always Rolls Along....I guess the best thing to do is when he visits you with his gasoline/diesel vehicle go ahead and fill up his tank. That is what people did in remote areas before filling stations were everywhere and you lived very remotely. I learned this from the tour guide in a remote Lake Tahoe Nevada Mansion when guest from the California coast would visit. (Just a hundred years ago . . . .)
Interesting video.
Did Ford just damage their chance of long term success by suggesting the Lighting is light years ahead of the F150's on their lots today?
I often listen to this guy from Denmark.
and yet they charge on.....l'll pick on the obvious target, Cali. Today, the wind blows, and they can't/won't keep the grid up.
Remember all new CA homes come with roof top solar panels to charge your EV.Great executive order from a State that is the largest net importer of electricity....
Good point. After losing power, you'll have to remember to start the charger back on.and yet they charge on.....
Newsom orders ban of new gas-powered cars by 2035
In a dramatic move to tackle climate change, Gov. Newsom announced that the state would ban new models of traditional cars beginning in 15 years.calmatters.org
when they shut the grid down they are going to have one heck of a time bringing it up with all those ^^^^ cars wanting to charge dead batteries.
Sounds like you must have a 200 HP electric tractor that you use all day.Ya right. An ev that needs 50-80 amps to charge. Id like to see an arrey that can output that level of power for 8-12 continuous hours.
What voltage do solar panels put out? 24V? 48V? More? Less? Ohm's law says half the voltage, twice the current for a given amount of power. Also keep in mind that inverters are not 100% efficient. Sounds like you'd need a pretty hefty array. Never mind that most of the charging would likely take place at night when those panels aren't putting out anything.People that have 8-12 hours daily to recharge are fine with a 15 amp 120 volt outlet assuming they only drive the average 30-40 miles daily.
Since we had 220v on a 40 amp breaker to our detached garage I set up to charge using 220v but the max the Leaf on board charger can draw is 26 amps and it tapers down from there.
Charging an electric car isn't as demanding like arc welding.
Solar panels are not used to directly fast charge EV's or power your AC powered TV or frig.What voltage do solar panels put out? 24V? 48V? More? Less? Ohm's law says half the voltage, twice the current for a given amount of power. Also keep in mind that inverters are not 100% efficient. Sounds like you'd need a pretty hefty array. Never mind that most of the charging would likely take place at night when those panels aren't putting out anything.
While the draw of a car recharger isn't that of a welder, neither is anyone running a welder at 100% duty cycle for 8+ hours straight either.
But more people are moving out of CA than in. So new homes there are not what they projected.Remember all new CA homes come with roof top solar panels to charge your EV.![]()
The same thing is going on in WV I read this morning. Not all states will be EV ready perhaps.But more people are moving out of CA than in. So new homes there are not what they projected.
I think they are talking about a flywheel the size of a house, not a flywheel in the house. The flywheel could act as an armature for a big motor/generator. Plus, it would not be a UPS, it would just even out the load. If the grid goes down, so does the flywheel.They tried flywheel UPS’s in the 70s and 80s, didn’t work out. Everyone went to static with battery backup.
The new ford advertisement for their truck says it takes 80 amps for 8 hours. I’m not making this up. and I never only drive 30-40 mile a day. More like 200 doing service calls.Sounds like you must have a 200 HP electric tractor that you use all day.
