ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 13,520
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
10 dollars says its being smacked down and damaged when you are on uneven ground.
As "Bavarian" says, the mower will want to move slightly sideways, it you have bottom link stabilizers on your 3-point that are rigid (solid) you should replace them with a flexible setup or make sure you have some slop in the setup. One iof the easiest ways to do this is to use chains and leave them just a little bit long (just enough for the wheel to caster around fully without reaching the limits of the chain). However, you do want to keep the chains just loose enough for the caster because the bottom link stabilizer does serve a purpose, it prevents the top and bottom links from bending sideways in a turn.One more thing. How tight are your sway bars at the lower 3 pt arms? If your tail wheel hits the ground and is not in line, it might want to push the mower to the side for a momemt. If the mower can't give in, the wheel might be overstressed.
You may have flex link, but it may not allow enough motion if you have really uneven terrain... Still think chains may give better relief...
As "DL Meisen" and "Gee Ray" said, the flex link has a limit to its range of motion. when you are mowing, you don't have any reason to need to keep the mower at an exact height, instead you want it to "float" with the terrain to provide you with a smooth finish cut. You set the tail wheel to the height that you like and the bottom link set will support the front. chains will allow you to pick up the mower for transport, obstacles, or other reasons, but allow the mower to float when in use.Remove the top link. If you want to pick the hog up use a piece of chain instead of the top link. This will prevent the loading of the tailwheel when you cross the ditches.
"hosspuller" has a really good example. If you pick up on the wheelbarrow handles, you are acting as the front wheels. The wheelbarrow wheel is the mower tailwheel. The wheelbarrow legs are acting as the front wheels. Because the link (the handle between the wheelbarrow wheel and its legs) is solid, it cannot allow the rear wheels of the tractor (wheelbarrow legs) to maintain ground contact. This causes all of the weight between the handles and the front wheel to be suspended. The tail wheel is not designed to handle this load. In order to fix this, cutting the wheelbarrow handle between the legs and wheel and installing a hinge would prevent this overloading and keep the tail wheel from having to support so much weight.Henro 's post # 7 has the problem nailed. You're loading the tail wheel in the dips of the ground. The top link or the cutter structure MUST allow the tail wheel to float up. Otherwise the wheel is supporting the whole weight of the tractor, like a wheel barrow
Your tail wheel should support that back of the mower, and the lift arms the front. On my brush mower the toplink connects to a pivoting U bracket and I keep that so it is vertical when mowing. Basically the mower should float on the front with the lift arms supporting it and allowing it to rise and fall if there is a large obstruction being run over. If I need the back lifted higher to get under it to work on the blades or if something gets tangled in it I adjust the top link to be rigid pulling the pivoting U bracket toward the tractor making a somewhat rigid connection. Put it back in the center position before mowing again. I've ruined at least a couple forks by backing up the far side of a ditch without lifting the whole mower. The far side of the ditch is too steep to allow the wheel and forks to pivot enough when backing.OK.....I'm doing something wrong.....way wrong.....and about to install my 3rd tail wheel fork on a 6' Bush Hog BH6 that's almost 3 yrs old. I figured the first one was due to the hydraulic top link failing, leaking down before I noticed, and i was just loading it up too much. But most of last season, I used the standard top link and this failure/damage happened after switching so that's not issue.
As far as I know, I'm not turning and smacking it into a tree, fencepost, some hard object. I have some hills, dips, ruts, and will occasionally dig a front corner into the dirt, but nothing so bad it should be loading up the tail wheel, but all I can think is a small ditch-like area I go over must do it.
I set to cut pretty short - about as high as a typical homeowner riding mower would cut at it's highest setting - 4.5" maybe?. At least i think that's short for a bush hog. On flat level ground the front of the frame (closest to PTO) is about 3" high. I adjust toplink so the back end (tailwheel end) is about 5-6" high. I think I'm doing that right - the rear slightly higher than the front. So maybe I'm overall just too low (I want about a finish mower height, but need something that can stand up to the occasional baseball-sized rock my land likes to just magically sprout). Maybe I need more of an angle and should have the back end more than just a couple inches higher? Not sure....I thought it was just supposed to be a couple inches higher to make it want to discharge rearward vs any random direction.
Anyway for standard cutting on fairly even ground the tailwheel doesn't touch the ground. Only inclines, ruts, hills, etc. I never really notice it loading up on the tailwheel, just that sometimes it does what it should and keeps the back end from dragging on uneven ground.
When I got my first 3 point shredder, I noticed immediately that 'something ain't right'. The shredder's connection to the tractor 3 point was rigid. What I call a standard, rigid, pyramid. As other have mentioned, there needs to be give when the shredder tail wheel rises.... It's like the fork was smashed straight down from the top. Wheel spins freely, shaft pivots freely.
