Midniteoyl
Super Member
- Joined
- May 20, 2013
- Messages
- 5,100
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
NOPE I understand what was implied very well but I think you don't understand what the u-shaped part is intended to do if not securely clamped tight.
When tailwheel goes over a rise or berm IF BOLT doesn't have u-shaped piece held tightly the center link & u-shaped will pivot lower similar to a hinge on a gate allowing tailwheel/rear of cutter raise with no bending/destruction of parts. The u-shaped part has been performing similar that since I was 1st employed by a farm equipment dealer in 1965. I'll repeat no need to change lift bars(#2) to chains.
Did you not actually read what I wrote or watch the video I posted? If I understand you correctly, than we are all in agreement on what the U bracket does and how it's to be adjusted and used.
Otherwise, I'm confused as hell as to what you are saying.
