It's time; either get started or....
/ It's time; either get started or....
The two bigger ports are suction, the 3 ports are pressure out.
The big one will be high volume, the smaller ones are lower volume.
Might use one of the smaller ones for swing circuit, the other for the outriggers and the big one for the rest.
Definitely do not use the port on the valve marked as Tank for anything but a low pressure return to the tank.
Aaron Z
Thanks aczlan, I suspected the larger ports would be inputs but the side with three ports are all the same I thought but yes, the one on the end opposite the shaft could be larger. I'll look again for a port marked as Tank.
The only ports that I can find with ID are on the opposite end from the shaft. The half inch port is stamped TK and the three eighth inch port is stamped PR. For now, I'm holding off with the "heart transplant" till I have tested the results of re-plumbing the tank return from the four-spool valves. I have it plumbed into a tee which in turn is plumbed into the to-tank port coming off the three spool valve set. Here's hoping this makes a pump swap unnecessary. I hope to save the Sta Rite pump off the Toro for another project.
The only ports that I can find with ID are on the opposite end from the shaft. The half inch port is stamped T1 and the three eighth inch port is stamped PR. For now, I'm holding off with the "heart transplant" till I have tested the results of re-plumbing the tank return from the four-spool valves. I have it plumbed into a tee which in turn is plumbed into the to-tank port coming off the three spool valve set. Here's hoping this makes a pump swap unnecessary. I hope to save the Sta Rite pump off the Toro for another project.
Still not looking good for the pump I'm using off the bale loader/stacker. Even after plumbing it correctly, there seems to be inadequate pressure. So now I have to see if there is any logical way to fit the Toro pump into the space the present one is in. The biggest problem I'm seeing is what to do about the two extra outputs. Just plumbing them all together is a doubtful way to go is my guess. Dividing up the various functions between the three outputs is far too complicated for my remaining brain cells to figure out :confused:. I'll have to see how much room I allowed for modifications once I pull the pump out of there. Stay tuned!!
/ It's time; either get started or.... #184
Do you have a high pressure gauge to see what it is doing?
I put one on the loader valve to see what is up. Or down ;) .
I don't have one that is specifically for testing hydraulics but I'm thinking an old gauge off a cutting torch, either oxygen or acetylene side might serve. In the meantime, I have the pump off. I can turn it by hand but it feels like there is a "load" even though the ports are open and there is no fluid in it. Is that normal? The Sta Rite pump I have on the bench turns freely and I can feel there is both suction and pressure. The problem with that one is the three outputs and how to manage the two I can't use.
/ It's time; either get started or.... #186
Four options for the extra pump sections:
1. Run them together to combine flows for all 3 sections (might need 3 check valves)
2. Tee them back into the line that returns to the tank (below fluid level)
3. Send them through a filter and back to the tank (again below fluid level to prevent aeration of the fluid)
4. Use them for an additional circuit with a separate valve
As for the gauge, a liquid filled 3000 or 5000PSI gauge is under $15 on Amazon, I would likely go that route.
Aaron Z
/ It's time; either get started or.... #187
Here is how those pumps are setup inside:
Gear pump:
Gear rotor pump:
It is likely a gear pump from the shape of the housing.
Aaron Z
/ It's time; either get started or.... #188
I would start with teeing a 3000psi or 5000psi gauge into the line from the pump to the valve to see what pressures you are getting from the pump.
Aaron Z
Thanks aczlan for that information. If I settle on that pump I'll have to plumb the extra outputs into an already busy return to tank circuit. Is that going to put more pressure in there or is there sufficient loss occurring in the scroll valves to make it a non-issue? I'm just not sure I want to add more hoses onto an already busy mess of them. And that's just to find out if this pump is any better than the one I took out. I'm leaning more and more towards a new pump and be done with it. That brings up the question of how much pump is right for the job. This is a small machine operating two inch diameter cylinders so a big pump should not be in there to begin with. I'm looking at a pump that has a .244 displacement and is rated at 4.26 GPM. I can run it at 600 to 3000 RPM so my 1200 or so speed is OK. Does that look about right for the job? It costs around 135$ taxes in. I hope that is the last big bite out of my back pocket but I won't count on it.
I have had time to do some calm meditating on what could be going on with the hydraulics and I have come up with two scenarios which I need to check out before I spend money on a new pump. The first scenario has to do with air entering the system ahead of the pump. Not impossible but because I don't see any leaks between tank and pump when the engine is off, that scenario is unlikely.
The other one, which I should have checked out before removing the pump and should have been a no-brainer is stalling of the belt drive under load. Because that is under the tractor and out of sight while I'm trying out the operation of the hydraulics, I never thought to check on that (another example of brain cell aging/decomposing) :rolleyes: . While I had the pump off, I opened it up to see if anything obvious showed up. It looks clean and I don't see any wear or sloppiness in there so I closed it up and tightened up the four bolts that hold it together. Now I can't turn it by hand but I'll loosen those bolts, spin the shaft back and forth and retighten the head bolts and retry till it works like it did before I opened it. If, when I have it all put back together, it turns out the belt(s) are slipping, I have an idler pulley for that.
/ It's time; either get started or.... #191
Again.
I sleuthed out the reason the hydraulics were not working - the second scenario has it!!:( The idler pulley doesn't help either because the two inch pulley driving the ten inch does not have enough sheave area gripping the belt to prevent slippage. So, I have replaced it with a three inch pulley and will try that tomorrow. If that fails, its back to the way I was driving it to begin with and experiment with the restrictors. I may even have to use a flow control to smooth out the operation of the machine. But for now, I'm relieved to have solved the mystery; solving the problem is so much easier when you know what it is!!(y)
Looks like I'm back to what I had working before. The problem with using the extra pulleys and belts along with all the other stuff already down there makes it almost impossible to mount the idler pulleys needed to keep the belts extra tight. So back to driving the pump with one belt from the engine to the pump and clutching that with the idler. If restrictors don't solve the too rapid operation of the cylinders, then a flow control valve is next. I'm relieved its not the pump.
/ It's time; either get started or.... #194
Now that I am back with the five inch drive to ten inch driven pulleys I still had to add serious tension on the idler to prevent slippage. Now, when I give it work, the engine stalls unless I have the throttle wide open. That engine should not have a problem operating the machine; it's a two cylinder 18 HP Briggs and Stratton. Like before, the boom and dipper are moving too fast which tells me the pump is a high GPM unit and not really suited to the task. I picked up a flow control valve today but have not installed it as yet. With all the fittings and extra hose I need to get it working, I'm wondering if a new pump that is matched to the job and costs almost the same, is the better route. Thoughts?
PS: I will pose much the same question on the thread I have going on the hydraulics forum.
/ It's time; either get started or.... #196
I got that fitting installed so all the hoses are in place. I found some minor leaks and fixed them easily enough. The thing that had me worried was would that old pump off the bale loader still pump. Well, it pumps alright!! The bale loader was a tractor towed machine so the pump was PTO driven at 540RPM max. The way I am running it is probably quite a bit faster. I'm guessing the engine is running a minimum 1200 RPM or more and the drive pulley to driven pulley cuts it down to half that. I'm going to have to find flow restrictors for all the cylinders as they're moving far too fast. The problem I'm having is sourcing those restrictors. Anyone know where to look?
Punch out small copper discs and drill 1 mm holes or even smaller (depending on the speed you require) through their centres and fit one at each cylinder joint. Nip them up tight to compress the copper and make a perfect seal. This will restrict the flow and reduce the speed of travel.
Shaunshep, welcome to TBN and thank you for that suggestion. I may be restricting some more of the connections before this project is done. I brazed a couple and on others took bolts and drilled the centers out to 1/16th", then tapped the fitting to be restricted just far enough to spin the bolt in a few turns and cut the bolt off with a cutoff blade in my angle grinder. Your method sounds simple and effective; just not sure how I'll punch out the discs. I might just snip them out in octagonal or hexagonal shape and bend the corners down till they fit into or over the fitting and proceed as you described from there.
I have been asked on a number of occasions what the specs for the pump are and have not been able to give an answer to that question - till now. Turns out that answer also explains what I have going on with the wonky operation of the hydraulics. The output measures a whopping 1.4 ci per rotation and even with stepping the speed of rotation down the volume of oil it tries to circulate simply stalls the pump or the engine or both. I have pulled the pump out and am about to install a .488 ci unit in its place. I'll need to make modifications to where the pump is mounted to accommodate dimension differences. While I'm at it I hope to install a pressure gauge so I can monitor that as well.
The new pump is in and after fabricating a mounting plate out of 1/4" steel plate I bolted it all together, connected the input and output hoses and was able to successfully test the operation of the cylinders. With the restrictors in place they all moved well without the previous issues so that was positive for a change. The temporarily installed pressure gauge showed good pressure in the 2000 psi range but it only registered any pressure when I moved the boom or dipper. I take that to mean the absence of backpressure in the system when no work is happening. I took the gauge out because I don't have a convenient place to mount it.
I have not tested its digging capabilities yet; that will have to wait for tomorrow. Today was taken up with switching the away and back hookups of the valves on a couple of cylinders and taking care of some seepage where NPT connections are being used. Its finally looking like I can dig with this machine. Tomorrow should reveal what its capabilities are.😰
I finally took time out from gardening and yard care, etc, and tried out the "digger". It became evident quickly that I have design flaws to correct. The swing cylinder broke loose; it is supposed to remain stationary while a link does the swing. Next, the dipper does not lift high enough to allow for dumping the bucket. I'm wondering if I should have made the boom straighter. Well, it's too late for that so I'll do some changes to compensate. It's pretty obvious what kind of "engineer" I've turned out to be!:( Lastly, there still seems to be slippage in the drive to the pump so I will need to address that as well. I may have to get smaller idler pulleys and build a double set that tensions by turning rather than pushing. Our Swisher Zero Turn has that for the deck drive.
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
2022 EZ-GO ELITE...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
2017 Ford F-450 Liftmoore 5000W 2 Ton Crane Service Truck (A61573)
2017 Ford F-450...
