Possible way to stop sliding-slipping down in Kubota "B" seat.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #31
Does Northern Tool still offer that seat? Did the bolt holes line up or did you have to improvise?
I replaced the seat on my B2710 with a Northern Tool seat and it was a huge improvement. I think this is the same seat, or at least pretty close. I've had mine for about 10 years. It did require a bit of fabrication to get the bolt holes to work, I used slotted angle. It also doesn't tip forward, something I really miss because it had that little tool box under the seat that I can't use anymore. That also complicates using the PTO without being in the seat, like if you want to use a log splitter. I modified mine so the engine will still die if I'm not in the seat, but I left a little pigtail that I can use to jumper the safety out, so I can get out of the seat and the engine and PTO will work.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #32
Maybe a solution for this, will also help the most annoying problem of sliding off my bed when I adjust the head end, up somwhat! lol
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #33
Looks like they do:
https://www.northerntool.com/shop/tools/product_200490177_200490177
I don't recall having to do any modifications. But, I seem to recall cussing a bit. So, if they're still the same, yes, the holes line up (but one has to play around a bit).
Pretty sure that you'll be happy with this seat. It's nothing special other than it just works (and it's cheap). The drain holes are a plus.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #34
Short term wear your seat belt.
Long term Cure for sucky Kubota seats
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #35
Double back sticky tape?
Or
Velcro on your butt?
I was going to suggest lag screws butt I think Velcro is a better choice:ROFLMAO:
Looks like they do:
Thank you. Having it fit on a B7800, like mine, makes it better. For a tractor that's primarily a lawnmower, it will be just fine. Cussing during installation is OK.
Beezfun--great seat but more than I want to spend on a mower. Tractor, yes. Thank you.
Mikester--Grammer is no doubt the best. I have a cab tractor with one and a Grasshopper as well and both are as good as it gets. Thank you.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #37
Hmmm?? All the suggestions for seat covers, and not a single pic...
Until this thread, never heard of or thought of sliding off a seat. Just doesn't happen.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #38
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #39
I've never had enough of a "slipping" situation to really call it a problem. I was given a foam "seat warmer". Just lay it down on the seat and sit on it. Kind of nice on really cold days - my M6040 is open station.
I DID notice - when I use this chunk of foam - there is absolutely no slipping, anywhere, what so ever.
Could be a quick, cheap answer. www.therm-a-seat.com Made in the USA. Lawrence, MA. It's what they call their fishing cushion. $9.99.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #40
2013 M59 seat vinyl was starting to crack along the top cushion.
Durafit seat cover from Amazon. KU05 KNT C
Durafit Seat Covers, KU05 SST for KUBOTA Tractors L45/M45.L48/M59.B25/B26 M108S LP MOWERS F2680/F2880/F3080/F3680 in SST Camo Endura Amazon.com: Durafit Seat Covers, KU05 SST for KUBOTA Tractors L45/M45.L48/M59.B25/B26 M108S LP MOWERS F2680/F2880/F3080/F3680 in SST Camo Endura: Automotive
Good fit, quality straps and Velcro to hold in place. Little more friction than the vinyl.
2017 Ford Taurus AWD Sedan (A55853)
2017 Ford Taurus...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2018 Ford Transit Van, VIN # 1FTYR2CG5JKA96646 (A54865)
2018 Ford Transit...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
378812 (A51573)
378812 (A51573)
