Possible way to stop sliding-slipping down in Kubota "B" seat.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #21
A piece of tool box liner should keep you from sliding off. And you don't have to wear those silly pants. ;)
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #22
Best solution is getting rid of the forward tilt of the seat. I wear real pants (Wranglers) most of the time. The 4240 has an upholstered seat. It isn't as slippery as the vinyl seats on the previous two Kubotas. That doesn't solve the problem. It creates Problem #2 outlined below.
Problem #1 is slipping forward on the seat. If the solution to Problem #1 is doing something to get traction on the seat, it creates Problem #2. That would be the discomfort of having one's trousers stay put when one's body wants to keep moving forward. Kinda reminds me of when the hotel in town wanted to economize. They eliminated the ballroom.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #23
Just curious: is this the same seat that shipped with BX machines for a while? That was hideous. I was ready to demand that the dealer haul the BX24 & accessories away when Kubota offered a $25 replacement seat. Been parking my elderly bodunkus on that for 10+ years and it's been fine.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #24
The seat is the part I like least about my otherwise fine B2910. Besides using the seat belt, I got a memory foam seat cushion that's great. Mine is from "Everlasting Comfort" but I've also heard good thing about a similar one (with a gel layer, too) from Comfi-Life. Smooths the bumps and much less slippery.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #25
My old M5030 seat would cause tailbone pain mowing or haying. Used a kitchen chair cushion with anti slip bottom helped a lot. The newer tractors seats are better but don’t do the long hours anymore. Do think I need to tilt back and space up just a bit on rubber blocks would help ergonomically. Impressed with what others said about seat covers so ordered a Durafit cover off Amazon to try.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #26
I replaced my BX seat with an aftermarket version after driving mine from one end of my property to the other and needing a chiropractor afterward. Ridiculous that any company would put the OEM seat on anything. My first Murray garden tractor had a better seat.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #27
I loved my smaller John Deere tractors (3020), the platform slopes up at the clutch and brakes and you can brace your feet.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #28
I've put over 1,000 hours on my B7800, in which case I think I have enough seat time to comment on this...
I had this very problem with the factory seat. Put up with it until the rails finally broke. I bought a replacement seat from NorthernTool (about $100 at the time). I've likely put at least about 400 hours on it and can state that it's FAR superior to the stock and that you really don't slip off. Note that I don't have a lot of slopes, so can't really comment on how that works out: but one should be wearing a seatbelt in such situations, so slipping around in the seat is less likely (the seatbelt, however is another thing I have a beef with- it readily tensions and after a while you find that you're being over-cinched and have to release the belt and refasten).
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #29
Double back sticky tape?
Or
Velcro on your butt?
Does Northern Tool still offer that seat? Did the bolt holes line up or did you have to improvise?
2014 Toro Workman HDX-D Diesel Utility Cart (A55851)
2014 Toro Workman...
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
25077 (A51694)
25077 (A51694)
1977 Gleaner A630 Corn Head (A55302)
1977 Gleaner A630...
