Possible way to stop sliding-slipping down in Kubota "B" seat.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #31
Does Northern Tool still offer that seat? Did the bolt holes line up or did you have to improvise?
I replaced the seat on my B2710 with a Northern Tool seat and it was a huge improvement. I think this is the same seat, or at least pretty close. I've had mine for about 10 years. It did require a bit of fabrication to get the bolt holes to work, I used slotted angle. It also doesn't tip forward, something I really miss because it had that little tool box under the seat that I can't use anymore. That also complicates using the PTO without being in the seat, like if you want to use a log splitter. I modified mine so the engine will still die if I'm not in the seat, but I left a little pigtail that I can use to jumper the safety out, so I can get out of the seat and the engine and PTO will work.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #32
Maybe a solution for this, will also help the most annoying problem of sliding off my bed when I adjust the head end, up somwhat! lol
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #33
Looks like they do:
https://www.northerntool.com/shop/tools/product_200490177_200490177
I don't recall having to do any modifications. But, I seem to recall cussing a bit. So, if they're still the same, yes, the holes line up (but one has to play around a bit).
Pretty sure that you'll be happy with this seat. It's nothing special other than it just works (and it's cheap). The drain holes are a plus.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #34
Short term wear your seat belt.
Long term Cure for sucky Kubota seats
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #35
Double back sticky tape?
Or
Velcro on your butt?
I was going to suggest lag screws butt I think Velcro is a better choice:ROFLMAO:
Looks like they do:
Thank you. Having it fit on a B7800, like mine, makes it better. For a tractor that's primarily a lawnmower, it will be just fine. Cussing during installation is OK.
Beezfun--great seat but more than I want to spend on a mower. Tractor, yes. Thank you.
Mikester--Grammer is no doubt the best. I have a cab tractor with one and a Grasshopper as well and both are as good as it gets. Thank you.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #37
Hmmm?? All the suggestions for seat covers, and not a single pic...
Until this thread, never heard of or thought of sliding off a seat. Just doesn't happen.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #38
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #39
I've never had enough of a "slipping" situation to really call it a problem. I was given a foam "seat warmer". Just lay it down on the seat and sit on it. Kind of nice on really cold days - my M6040 is open station.
I DID notice - when I use this chunk of foam - there is absolutely no slipping, anywhere, what so ever.
Could be a quick, cheap answer. www.therm-a-seat.com Made in the USA. Lawrence, MA. It's what they call their fishing cushion. $9.99.
   / Possible way to stop sliding-slipping down in Kubota "B" seat. #40
2013 M59 seat vinyl was starting to crack along the top cushion.
Durafit seat cover from Amazon. KU05 KNT C
Durafit Seat Covers, KU05 SST for KUBOTA Tractors L45/M45.L48/M59.B25/B26 M108S LP MOWERS F2680/F2880/F3080/F3680 in SST Camo Endura Amazon.com: Durafit Seat Covers, KU05 SST for KUBOTA Tractors L45/M45.L48/M59.B25/B26 M108S LP MOWERS F2680/F2880/F3080/F3680 in SST Camo Endura: Automotive
Good fit, quality straps and Velcro to hold in place. Little more friction than the vinyl.
More info coming soon! (A55851)
More info coming...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2009 Utility Trailer Mfr. 53ft. T/A Dry Van Trailer (A55852)
2009 Utility...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2017 PETERBILT 579 DAYCAB (A55745)
2017 PETERBILT 579...
