New to me 2210d
/ New to me 2210d #41
Looks like damn near the same hog if not THE same....
International Technologies?
IT is still around to a degree. Another company bought them out, they still have old stock on the shelves out in California. I have a post hole auger imported by them. If it wasn't for the expensive sipping, I would have ordered the OE cutters and the tip from them. This goes back 4 years though.
/ New to me 2210d
Well I finally remembered to check this today.... the knob is very hard to turn w a load (5' hog) lifted but I closed it all the way, opened 1/4 turn, lifted, then closed it as I killed the engine....
The hog stopped lowering as soon as it closed and stayed there till I opened the valve again.... Safe to say the issue is not the cylinder... what's next?
Edit... here's what's in my manual...
First two ruled out....
/ New to me 2210d
I did get my new ign switch installed today and magically my 'clutch' issues are gone... LOL
/ New to me 2210d #44
What about a clogged vent tube? This is the funny U-hook tube out the back. I also use it as a linch pin holder when switching attachments.
/ New to me 2210d #45
Mine won't stay up either unless I lock it. I had trouble with the linkage to the valve. So much play in it the height would move. I was able to correct that as long as the tractor is running. Which for me is very seldom do I even have to use it. YM2000 vent which appeared to be clogged by Dirt Dobbers. Never the less It was clogged just unscrewed it.
/ New to me 2210d
What do you guys think of this....
Hydraulic oil coming out past the pto shifter while driving... pto engagement status doesn't matter...
Fill level is perfect according to the dipstick...
/ New to me 2210d #47
I used a o-ring around the bottom of the rubber boot. Worked for me. Mine is in better shape and not power shift causing a problem but it's worth a try.
/ New to me 2210d
Hmmm dunno... will check
Is that supposed to go over the boot?
Is it normal to have oil in the boot?
/ New to me 2210d #51
Don't know whether under or over?? Have you made sure your transmission vent is open? (On top of the rockshaft)
/ New to me 2210d
Need to... guess I'll walk over there now....
/ New to me 2210d
Well good news and bad news.... it's open but it's also too open...
/ New to me 2210d
At some point I'll work on getting the old one out n go from there.... kinda hope it's threaded as that might be easier to remove..... unless it's harder lol
/ New to me 2210d #56
It's threaded. And an easy-out should remove that ... easily!
See if Hoye has the replacement. It's common to replace them. People think they can attach a tow rope there. Nope.
I was lucky. That part and several similar trivial parts were available for my YM240 when I bought and renovated it. The local VN importer would salvage anything I needed, off the warranty returns that he had parked out back.
/ New to me 2210d
Good deal... winston was kind enough to link the replacement above
/ New to me 2210d #58
The tube is Part# AB-42280 Repl. #1941150.42280 to many models to list apparently. Fredricks has a few 1000 I'm sure.
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A59914)
2025 HOMESTEADER...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
