New to me 2210d
   / New to me 2210d #41
Looks like damn near the same hog if not THE same....
International Technologies?
IT is still around to a degree. Another company bought them out, they still have old stock on the shelves out in California. I have a post hole auger imported by them. If it wasn't for the expensive sipping, I would have ordered the OE cutters and the tip from them. This goes back 4 years though.
   / New to me 2210d
Well I finally remembered to check this today.... the knob is very hard to turn w a load (5' hog) lifted but I closed it all the way, opened 1/4 turn, lifted, then closed it as I killed the engine....
The hog stopped lowering as soon as it closed and stayed there till I opened the valve again.... Safe to say the issue is not the cylinder... what's next?
Edit... here's what's in my manual...
First two ruled out....
   / New to me 2210d
I did get my new ign switch installed today and magically my 'clutch' issues are gone... LOL
   / New to me 2210d #44
What about a clogged vent tube? This is the funny U-hook tube out the back. I also use it as a linch pin holder when switching attachments.
   / New to me 2210d #45
Mine won't stay up either unless I lock it. I had trouble with the linkage to the valve. So much play in it the height would move. I was able to correct that as long as the tractor is running. Which for me is very seldom do I even have to use it. YM2000 vent which appeared to be clogged by Dirt Dobbers. Never the less It was clogged just unscrewed it.
   / New to me 2210d
What do you guys think of this....
Hydraulic oil coming out past the pto shifter while driving... pto engagement status doesn't matter...
Fill level is perfect according to the dipstick...
   / New to me 2210d #47
I used a o-ring around the bottom of the rubber boot. Worked for me. Mine is in better shape and not power shift causing a problem but it's worth a try.
   / New to me 2210d #48
Is this o-ring missing? O-RING
#4 on drawing
   / New to me 2210d
Hmmm dunno... will check
Is that supposed to go over the boot?
Is it normal to have oil in the boot?
New/Unused AGT Industrial Bucket Mixer (A57454)
New/Unused AGT...
2021 John Deere 333G (A55272)
2021 John Deere...
E-Z Trail 700 bu Auger Wagon (A59814)
E-Z Trail 700 bu...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED SDLANCH SDLD25 CRAWLER DUMPER (A58375)
UNUSED SDLANCH...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
