Should curl cylinders bleed off with tractor running?
   / Should curl cylinders bleed off with tractor running? #1
iptman
Gold Member
Northern VA
Scag Tiger Cat, 61", Kioti CX2510
I was helping a buddy of mine install a front bumper on his 4Runner the other day and with the tractor on and idling the forks would bleed off slowly causing the forks to start pointing down. I know this will happen if the tractor is off but I was surprised it was doing it with the tractor running. Is this normal? Here's the setup. Bumper and winch weighed maybe 130 pounds.
   / Should curl cylinders bleed off with tractor running? #3
Mine definitely does, for example carrying a bucket of material from one side of the property to the other, I usually "choke up" once or twice on the way to avoid losing material.
   / Should curl cylinders bleed off with tractor running? #4
About the only thing on my tractor that does not leak down when the tractor is running is the 3 Pt Hitch height adjustment - I believe there is a position sensor on that, and it auto-corrects.
   / Should curl cylinders bleed off with tractor running? #5
Running makes no difference. There is no control to automatically correct for leak-down in the FEL, unlike on the 3-point hitch.
   / Should curl cylinders bleed off with tractor running? #6
I had the same thing, and like many others in this thread, though it was pretty normal. Just internal seals doing what they do. That was until I installed a directional inline flow control valve to "resist" the dump action of the loader. I originally did it to stop the floppy bucket when back dragging, but discovered the leak down I previously thought was normal was in fact happening through the joystick control valve. The valve wasn't making a perfect seal on the rod-end circuit, so it would leak down through the valve. Air would enter the other end of the cylinder, presumably through the valve.
Now, when I park the tractor, days later I can come back and step on the tip of the forks or bucket and its still rock solid.
   / Should curl cylinders bleed off with tractor running? #7
I recently needed to service my front C/S driven hydraulic pump installation.
While doing so I decided to replace the pump seals.
When I work up front I always have a keeper bar to hold the FEL in the raised position and once I finished that was removed.
Well 2 days later and my FEL remained elevated.
While I always thought my selector valves were leaking it turned out that It was a simple $20.00 oil seal at the pump.
Dirt and a bit of corrosion on the pump shaft had gradually worn the sea's fine edge.
(won't happen again as I devised a deflector)
   / Should curl cylinders bleed off with tractor running? #8
My current tractor has very low hours on it, and I haven't observed the cylinders drifting yet. A couple of times I've parked it (in the closed barn for safety) with the bucket up, and it looked the same a couple days later.
I know, I should enjoy it while it lasts....
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
Pat's QH and hydraulic top-link.
Pat's QH and...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2021 BOBCAT S66R SERIES SKID STEER (A60429)
2021 BOBCAT S66R...
2014 VOLVO A50G WATER TRUCK (A60429)
2014 VOLVO A50G...
