CK2610 loader upgrade
/ CK2610 loader upgrade #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
Anyone with a 2610 upgrade their loader to a kl4030? Love my tractor but wish it had a bit more lift capacity. I would like to trade my kl2610 loader for the kl4030. Has anyone done this? Is the 2610 able to handle heavier lifting? Thanks.
/ CK2610 loader upgrade #2
The CK2610 is the same frame as the CK3510 & CK4010. The CK2610 will handle the loader.
My experience is that used loaders by themselves do not have a very high trade in value at dealers.
Does anyone have any idea what a KL4030 costs?
/ CK2610 loader upgrade #4
I loved my tractor also but the lift capacity was not what I had hoped for ( a few hundred lbs shy )
so I replaced the rams .. warnings in place that the engineering was not based on stronger hydraulics
however, it was a risk I was willing to take vs not being able to use the tractor I just bought as intended
Comparing the kl2610 and the kl4030 I can't see much difference other than the hydraulic cylinders? I wonder if you could just change out the the cylinders instead of getting a whole new loader?
/ CK2610 loader upgrade #7
Changing the cylinders would be a lot cheaper for sure!
/ CK2610 loader upgrade #8
Following this for sure, that’s the only complaint about my ck2610, is the kl2610 loader. I asked when I bought mine if we could upgrade to the one the ck3510 had, and the dealer said no. Than like 2 months later, they started coming with the bigger loader....
/ CK2610 loader upgrade #9
I have the same issues with my CK35. The KL130 loader does not have great capacity.
Before totally giving up you should measure, and make sure the relief pressure is set to spec.
My relief pressure was 150psi low, I turned it up 350psi over spec. The loader is now more usable, and for me, I don't think its worth the money for what little capacity improvement I would get.
I would have no idea how or where to check the pressure. I was quoted $1750 plus my loader to have the KL4030 installed.
/ CK2610 loader upgrade #11
Honestly, I do not think that’s too bad of a deal. I wish my dealer would do that.
/ CK2610 loader upgrade #13
$1750 plus your old loader? WOW... thats a good deal... go for it!
Went ahead and ordered a kl4030 loader. I got another quote that was $3400 plus my loader. I'm going to keep my current 60" bucket as I welded chain hooks on it and have a tooth bar that was made for it by BXpanded. I have to wait till July or August to get it.
/ CK2610 loader upgrade #15
Where are you located? Just asking as I would do the same deal with your dealer if not too far away.
I am in North Central Pa. Just west of Wellsboro Pa.
/ CK2610 loader upgrade #17
that is a heck of a deal ,, I just ordered stronger tilt rams to go with my oversized lift rams i put on last month
I will be into this about a grand for rams and hoses and while it will finally do what I need forklift wise the frame won't be rated for the rams potential now so damage could be possible if I am not careful what i lift or curl
I would have jumped on an upgraded FEL at a reasonable price
Excavator trenching bucket- one bucket per lot (A63689)
Excavator...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
Hydraulic rail grinder (A61307)
Hydraulic rail...
YALE FORKLIFT (A63291)
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
Kubota ZG222 (A60462)
