Diesel Fuel Water Separator
/ Diesel Fuel Water Separator #1
Chewwy
Upstate SC, Near the Electric City
Kubota L3240, MF 265, MF383
At one time a lot of diesel tractors came equiped with fuel water separators. Doesn’t seem to be the case anymore. Anybody know why this is? Has fuel quality improved that much?
/ Diesel Fuel Water Separator #3
Did not know they'd stopped providing them. They stopped providing gasoline filters.
In 38 years driving 3 diesel cars and 17 years driving 3 diesel tractors and now 9 years on a diesel generator, I've NEVER had a water in diesel problem.
/ Diesel Fuel Water Separator #4
"NEVER had a water in diesel problem", because of the water separator did its job or never had water in your diesel to start with?
/ Diesel Fuel Water Separator #5
Welllll, ya still gotta empty it
/ Diesel Fuel Water Separator #6
Never ever had water in diesel. Never appeared in water separator on tractor nor generator. Cars didn't have them.
/ Diesel Fuel Water Separator #7
Can you show us all the new diesel tractors without water separators?
/ Diesel Fuel Water Separator #8
I was quite surprised to find out that a "premium" brand like Kubota no longer includes a simple strainer/screen at the fuel tank fill neck. Might not sound that big of a deal but sure prevents a lot of stuff to get inside the tank in the first place.
I doubt it. I KNOW of only one that doesn’t, my 2007 Kubota. But I doubt that it is unique. I am talking about the ones with a drain port or plug for removing accumulated water. It is usually part of the filter cannister. Pretty much all verticle mounted filters can separate water in the cannister. But that does no good if it can’t be drained.
My 64 David Brown, 87 Ford 555B, and 77 MF 265 all have drain plugs on the fuel filter.
/ Diesel Fuel Water Separator #10
That sounds a lot more like a tank sump than a water separator.
I've often caught water in the separators, never enough (in m opinion) to kill the motor at one time but accumulation over a summer or winter might be enough probably less than a table spoon I dump usually with fluid changes. Another indicator if you don't see it is the steel mesh rusting inside the separator, needs an oxidizing agent to rust and I'm fairly certain diesel fuel is not one.
Also in regards to a tank sump, I'm not a huge fan. I'd rather the material/water get drained constantly than have a big ball of sludge rolling around in there ready to splash into my fuel system when I'm in that highly awkward uneven terrain where I really don't want my tractor to die. There's also enough bacteria you need to be worried about in diesel without feeding it unnecessarily to grow your own special colony.
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
New 20' Container  (A62679)
New 20' Container...
Rolling Shop Stool (A66408)
Rolling Shop Stool...
CATERPILLAR D4H CRAWLER DOZER (A64277)
CATERPILLAR D4H...
2022 John Deere Gator (A64194)
2022 John Deere...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
