Single Cylinder Plumbing Issue
/ Single Cylinder Plumbing Issue #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
I have a 8560 Mahindra with a open hydraulic system.
JD 7200 planter uses a single hose cylinder to operate the Row Markers when the planter lift cylinder is activated. The supply to both cylinders is from one remote with 2 hoses to operate the double hose lift cylinder. One line tees off to the single hose marker cylinder.
My question is, "Can a single hose from the cylinder operate properly in the Open system?
I want to separate the Lift cylinder from the Marker cylinder to operate each independent from the other.
Would eliminating the Tee and using a single hose for Marker work and not damage the system??
Thanks In Advance!
/ Single Cylinder Plumbing Issue #2
You can. You must use an open center valve, since you have an open center system. It must be connected in series with another valve.
Can I eliminate the tee, extend the single hose to second remote and it operate properly- power up, gravity down?
JD tractors with closed systems will work this way. Will open system work??
/ Single Cylinder Plumbing Issue #4
If you already have an available remote, yes, remove the tee, and run the line. If you have to add another valve (remote), I was saying it has to be plumbed correctly and be an open center valve (remote).
Thanks,
I do have 2 remotes (wish I had 3rd)
Just double checking if this is worth doing.
2014 Gradall XL3100IV 4WD Rough Terrain Wheeled Excavator (A61567)
2014 Gradall...
2011 Ford F-250 Knapheide Service Truck (A61568)
2011 Ford F-250...
New/Unused CFG Industrial QK18R Mini Excavator (A61166)
New/Unused CFG...
2008 IC Corporation PB105 School Bus (A60352)
2008 IC...
Kubota SVL97-2 Skid Steer (A61166)
Kubota SVL97-2...
11R24.5 Pivot Tire (A62177)
11R24.5 Pivot Tire...
