pittsburgh bottom plow
/ pittsburgh bottom plow #1
Jimc295
Cleveland GA
Massey GC1705, Kubota B7100
Anyone know about this plow. It could use some parts replaced but I cannot find anything on Pittsburgh plows online.
/ pittsburgh bottom plow #2
We just sold one which had belonged to my father. I believe that they are now this company Taylor Pittsburgh as the result of a merger. I don't see that they carry plows any more though.
Depending on what you need, agri supply is a good place to find replacement parts. Plowshares | Agri Supply
I am finding some information on Taylor Pittsburgh but very little to nothing on a single bottom plow. so far I also have not found a matching plow share it has a 3 hole pattern with the front 2 holes close together. I've always heard once on the internet it is always there but I can not find anything on this plow. the share measures 12 inches and that complicates it even more. If anyone could identify the plow by model # that might help me find a substitute. I am gonna start cleaning it up so I'll post more pics later.
/ pittsburgh bottom plow #4
It's probably a copy of an old Massey or Ford/Dearborn. You can take measurements of all of the bolt holes and spacings, there are plenty of suppliers that offer that data readily on their websites.
I found this image, states the 12" is 3 hole
/ pittsburgh bottom plow #6
That is EXACTLY the same single bottom moldboard plow as I have. Mine is an 18" model, purchased new in '83. The plow still has the product info sticker on it. There is NO model # indicated.
Pittsburgh Implement Division of the Pittsburgh Forging Co. Serial # 132925
Years ago I looked for the Pittsburgh Forging Co - I think it's now called - AMPCO Pittsburgh Corp.
It's too heavy to man handle. So....this is the only picture I have of it. Weeds are pretty much covering the share. I mainly use it to cut drainage ditches. It's a real beast at turning the soil. Especially with the Kubota M6040. If you want added pictures, let me know. I could easily clear the weeds for added pics.
It's too heavy to man handle. So....this is the only picture I have of it. Weeds are pretty much covering the share. I mainly use it to cut drainage ditches. It's a real beast at turning the soil. Especially with the Kubota M6040. If you want added pictures, let me know. I could easily clear the weeds for added pics.View attachment 696388
Well this helps. I just added a new post with some new info. I removed the share and it had Star MF co stamped in the back of it and numbers HS 111 I think the stamping was light and rust has obliterated some of the letters.
What I am looking for is very very close to the Oliver/White 0 12-3
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2022 FREIGHTLINER...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2015 CATERPILLAR 232D SKID STEER (A65056)
2015 CATERPILLAR...
PORTA POTTY (A67714)
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
