Ethanol gas evidence
/ Ethanol gas evidence #21
I bought a walk behind mower yesterday and started messing with it today.
It ran last season and was left with ordinary pump gas with 10% ethanol.
Not only the bad gas, and cleaning the carb bowl, main jet, float, etc.
Look at this nice surprise from the plugged up fuel line.View attachment 695196
That’s a longer drill bit it used to go through it ramrod style. This came out the opposite end on the first pass.
I have found that with a product called PRI G I never have to drain fuel at the end of the season or worry about the ethanol. I have used this stuff for years and it works great. No more varnishing or plugging and the fuel stays fresh. Follow the link and read up on it, it is amazing. They have PRI G foe gas and PRI D for diesel.
/ Ethanol gas evidence #23
Each year I run dry the: mower, tiller, pressure sprayer, 2 weed eaters. Add 2 oz. of Husqvarna fuel I bought at Lowes. Restart for 15 seconds, shut them down, put them up for the winter. Works every time.
/ Ethanol gas evidence #24
Best thing to do is not store the mower outside or even under an awning. Ethanol is not a problem until you add water.
@ArlyA I wasn’t blaming the world problems on Ethanol additives. If you think it was something else, I’m openminded.
It appears to be the original fuel line. I had heard of this happening with ethanol gas is why I think this is what caused it.
I run Stabil in most of my small engines when I put them up or they are low usage. I want to try some SeaFoam per recommendations here but haven’t ran across it yet to buy.
I try to run most things out of gas. The chainsaw on the tractor usually has some but it always starts but usually no longer than a month or two.
But I manage to forget something and get to take the bowl/carburetor apart every year to reinforce my desire to drain or run STABIL in everything before letting it set up.
/ Ethanol gas evidence #27
Luckily for me, the next county over has non-ethanol fuel, run that with stabil the past 2 years. Haven't had to do any repairs or drain any fuel systems since, ethanol has its place, just not best for intermittent use equipment.
I still run a stabilizer in every can I fill because I never know when a peice of equipment will be done for the year and I don't want to have any surprises.
/ Ethanol gas evidence #28
At home, my 1992 push mower with a B&S engine starts on the 2nd or 3rd pull each year. The only thing I do is let it run out of (regular) gas and add oil through the spark plug hole before storing it in the non heated shed for the winter. The following spring, I replace the oil. Only maintenance this mower has seen is a new carb film and the primer bulb five years ago.
As for my 1993 snow blower with a Tecumseh engine, I shut off the fuel valve after every use and let it starve, put oil in the spark plug hole before storing it in the spring in the garage and stabilizer in the fuel tank. Next fall, I change the oil. It has seen no maintenance and don't even bother plug it in to start it. It starts on its first pull.
As for my 1995 snow blower with a Tecumseh engine at the cottage, it sees the same maintenance as the 1993 above but being stored in an non heated shelter, I use the electric start to start it and it always starts after a few seconds.
As for my 2003 generator with a Tecumseh engine at the cottage. It sees the same treatment as the blower but is always a pain to start. Once I get it going after several pull (wish the flywheel had teeth so I could add an electric start!) it starts but stops right away. I have to squirt carb cleaner for several seconds after it starts to keep it going. Once it has started though, it runs fine.
As for my 2010 log splitter and 2016 wood shipper with their Chinese engine see the same treatment as the blowers and always starts after two to three pulls.
Next is the 2016 garden tractor and 1992 boat. These having no fuel shut off, I put stabilizer in the tank and run it for about five minutes. It then sees the same treatment as the blowers, except the boat being oil injected do not need an oil change.
/ Ethanol gas evidence #29
Same here. I think we're good here in NS as far as ethanol goes, I check it every couple of months and haven't came across any ....yet.
I'm of a different mindset LOL. I fill it up with stabilized fuel as always. Shut the fuel off, let it run for half a minute or so and then kill it. My thought is that by running it for a bit with the fuel shut off the needle and seat won't be constantly hard against one another and leaving a depression in either. The stabilized fuel remaining in the fuel bowl will stop things from drying out.
I bet if you ask 100 people how they shut down equipment, you'll get 99 different answers LOL...........Mike
/ Ethanol gas evidence #30
In all our occasional use gas engines like the lawn mower, weed whackers and snow blower and even the 6x6. We keep seafoam in them all year areound which is less costly than having its fuel system cleaned out.
/ Ethanol gas evidence #31
I've had to rebuild two carburetors because of using gas with ethanol. The gas had a fuel stabilizer in it with an ethanol treatment. After that, I gave up on gas with ethanol in it. There is no gas station locally to buy ethanol-free gas, so I buy either Torco or VP ethanol-free gas from an auto performance store The gas is expensive, but the equipment always works and I don't have to worry about leaving gas in the equipment.
/ Ethanol gas evidence #34
One ounce per gallon?
Gee, I'm not into all those exacting measurements!! :LOL: I try adding about 1/3 of a can per 5 gallon fuel can. Seems if your gasoline is going to sit for a long time or get warm, then you might need to be more exact than I am.
/ Ethanol gas evidence #35
I've had the stablie brand fail for me. No more, now I will only use seafoam.
Check this link that @mikester posted 10 days ago. Not sure I'll be using Seafoam to stabilize gas. I'll mostt likely use it to 'clean' an engine.
/ Ethanol gas evidence #36
I had years of nonstop heartache and pain with small engines and ethanol gas (no additive). I’m a slow learner but one day I decided to switch to 100% gas (still no additive) and I’ve never had a single problem since - not one. My push mower gets parked around halloween with whatever happens to be left in the tank and 6 months later it still starts on the first pull and runs like new. Is the ethanol problem a myth? Maybe, but all my problems magically and immediately disappeared once I stopped using ethanol gas so it’s all I‘m going to use.
/ Ethanol gas evidence #37
My experience exactly.
Brand new equipment may tolerate it but the materials used in older equipment are destroyed by ethanol just like that fuel line.
Even if the materials tolerate it, ethanol still absorbs and holds water from the air, when the gas in the tank or carb eventually evaporates it leaves the water behind. If you have metal tank or float bowl it rusts.
The same principle is why we used methyl hydrate to remove water from gas tanks in the past.
/ Ethanol gas evidence #38
I use 100-octane ultra-low lead avgas in my small engines. Ethanol-free! I get it from a nearby county airport.
The equipment runs great on it, and at the end of the season I just run the tank dry. Things start right up at the beginning of the next season.
I make sure there are no sensors or catalytic converters in the exhaust system, as the small amount of lead would foul those in no time. On the spark arrestor screen of a water pump I use for many hours at a time, there is a slight buildup of yellow dust that may be due to the lead in the fuel.
You might be able to find gas without ethanol near you using the Ethanol-free gas stations in the U.S. and Canada website.
/ Ethanol gas evidence #39
I hear you and totally agree. Ive gone to diesel engines on equipment I need to be reliable. Small gas engines these days seem to be made disposable and cheap as possible with zero adjustments. Ethanol gas isn't helping anyone but the politicians because they don't have to deal with trying to implement any kind of efficiency/emissions standards.
/ Ethanol gas evidence #40
My experience also.
2012 CARGO CRAFT 24' T/A ENCLOSED TRAILER (A65643)
2012 CARGO CRAFT...
2000 International 4900 Tandem Truck (A66285)
2000 International...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
CATERPILLAR 926M WHEEL LOADER (A65053)
CATERPILLAR 926M...
