Woods RD990-X Finish Mower
   / Woods RD990-X Finish Mower #11
As strictly a backup for a Zero Turn do you think 28 PTO HP would be enough to run a RM90-2? Grass only and probably never above ankle high.
Asking because there's one for sale locally for cheap that doesn't look bad for its age.
Probably.
   / Woods RD990-X Finish Mower #12
They’re a tough mower. I bought mine used in 05 and it was probably 10 years old then. I’ve put blades on it twice, replaced the seals and bearings in the wheels once, a new Drive belt once, and a year ago added a stiffener plate across the front and welded up a few cracks in the deck. Also painted the underside of the deck. I use it to mow 5 acres weekly. When I bought it the gearbox seal was toast and the previous owner had filled it with grease. I installed a fitting in the plate on top of the gearbox and it gets 50 pumps with the grease gun before every use while greasing the wheels every other use. It’s a great mower and if I ever have to replace it I will get another 990. 6A901E4E-4C40-48E5-AED4-638A8950C5FC.jpeg4CF6745A-AC4C-412C-A820-97746BD75213.jpeg
   / Woods RD990-X Finish Mower #13
I have a Woods RD8400, which is similar to the RD990 and I pull it with a Kubota B7800 in conditions similar to what you describe. No problem at all for my 30 engine and 22 pto horsepower.
   / Woods RD990-X Finish Mower #14
I bought a new RD990x last fall to use on my Ford 3000. I only used it for about an hour to mulch up some leaves before putting it away for the winter. It seems like a really nice unit — I’m looking forward to seeing how it performs in various scenarios this year and beyond. I’m combining a finish mower and brush hog with this purchase, since my brush hogging is very infrequent and really is only cutting golden rods and similar veg., no thick brush or sapling cutting.
Quick Update on the RD990-X - It is a beefy mower and cuts extremely well. I'm still waiting on the growing season to really get going in central Florida. We've had a dry spring so things aren't really cranking just yet. That being said, I have mowed some light brush and cool season weeds and it has cut very well. The lifting power is unreal. My zero turn struggles to pull up light wispy weeds and this 990 doesn't miss anything. I'm anxious to get it into a realy thick pasture in mid summer to see what it does.
My zero turn is a Toro Titan 54" with 23hp Kawasaki. I mow at 7-8 mph regularly. On the tractor, I'm usually in 4 or 5 out of 8 speeds and averaging 5-7 mpg. I have been able to cut my mowing time by 75%. The 70hp Kubota I'm using uses about 4 times the fuel as the Kawasaki. Since I'm saving so much time my fuel cost is pretty comparable.
I cannot stress enough how stout and well built this mower is. You can see a large 2.5" square rectangular tube running across the front of the mower deck. My 8,000 lbs tractor grunts a little and you can feel it pick up the mower. Here's a few pictures
I'm still really pleased with the 990X. Its been a great mower. The quality of cut is unparalleled. I got a little worried about some tall weeds it wasn't cutting and then I realized it was because the blades had finally worn out and weren't providing as much lift. I threw on a new set of blades and voila, back to a perfect cut regardless of the height of the grass. I did run into a tree with one of the front wheels which bent the caster shank. It doesn't affect anything except I can't adjust the height any lower because of the bend.
   / Woods RD990-X Finish Mower #17
I started out with a 72” Land Pride, then a 84” Bush Hog then a 110” Befco RFM : all rear discharge.
I mowed around 15 acres at 4” height.
I liked the BH RDTH84 the best.
This Woods 90” would be an ideal size.
I sold all three & went with a 72” Zero.
   / Woods RD990-X Finish Mower #18
I've bent a couple of the wheel arms and the shafts a few times now and have had to have them repaired. The mower is nice ballast since it's heavy but it's big and easy to to accidentally run into things when focusing on what's on the forks or in the bucket...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2007 FORD F-450 SUPER DUTY (A58214)
2007 FORD F-450...
2020 CATERPILLAR 289D3 SKID STEER (A52709)
2020 CATERPILLAR...
GAME FISHER 5HP OUTBOARD MOTOR (A58374)
GAME FISHER 5HP...
202473 (A54757)
202473 (A54757)
(2) LP GAS TANKS (A58374)
(2) LP GAS TANKS...
