Forward Exit Horizontal Exhaust??
/ Forward Exit Horizontal Exhaust?? #21
I like the underslung to rest exhaust on my old ford tractor...
That said all my others are front and I wear respirator when using all day and notice a difference but I have always been susceptible to dust, pollen, etc...
/ Forward Exit Horizontal Exhaust?? #22
I have a MF 135 diesel with the exhaust exiting downward under the left rear axle. We’ve been using it for almost 50 years with a rotary cutter and a flail a bit. Unsure of what the issue might be using a flail. Other than getting ‘gassed’ when hooking up an implement. I do prefer the front horizontal exit on my Kubota for that reason.
My dad had an old one row 3 pt tobacco transplanter we used to set out tomato plants. Talk about getting gassed by the rear diesel exhaust. He claimed I couldn’t drive a straight row so I always got transplanter duty. He was no dummy. :sneaky:
Similar to this:
/ Forward Exit Horizontal Exhaust?? #23
Modern tractors of any size have a DPF, and the exhaust thus has virtually no odor.
Old junk smells, as do the low power newer models without a DPF.
/ Forward Exit Horizontal Exhaust?? #24
My Kubota M62 exhaust exits forward and down, and will stir up a dust cloud in dry weather like we're having now. The dust is a real PITA, enough so I'm thinking about changing the exit angle to something more level. I don't notice the exhaust fumes, but it is a Tier IV engine.
/ Forward Exit Horizontal Exhaust?? #25
My Deere 4320 compact came with a pipe that blew the exhaust out just aft of the front axle. I couldn't stand the fumes, so I bought a kit to convert it to vertical. It required cutting a hole in the hood, but it solved the problem and looks good. One downside is that you have to remember to remove the pipe before attempting to open the hood. It lifts off easily with no tools.
/ Forward Exit Horizontal Exhaust?? #26
I had a Yanmar with a vertical exhaust, now I have an LS which exhausts to the side and exits forward. never smell anything.
/ Forward Exit Horizontal Exhaust?? #27
OOSIK, in the Alamo Owners Manual in the "Hazards section" and its sub section of "FIRE PREVENTION GUIDELINES" in of the owner manual it says "DO NOT OPERATE mower on a tractor equipped with under frame exhaust" and that is all i know.
I wonder if the exhaust exits on the left rear side if the heat could effect the belt life of the fail mower?
I never hook up while my tractor is running.
My guess (and it is only a guess) is this has to do with older diesels not dealing with unburnt gases exiting with the exhaust causing an increased fire risk of these gases being collected under the fail mower box and the risk of a spark. Again purely a guess. On finish mowers and rotary cutters, these gases would likely go over the top of the mower.
/ Forward Exit Horizontal Exhaust?? #28
Question as I only have a tractor with a vertical exhaust stack.
Do forward exiting horizontal exhaust system found on many cause the operator to breath in lots of exhaust fumes?
I have a Yanmar SC2400 that has the exhaust pointed out the front of the motor housing, the only time I even notice where the exhaust is coming from is when I start the engine in cold weather and I get a plume of smoke from the front. Once the engine warms up a bit I don't see or smell the exhaust.
The exhaust pipe is about 12" higher, approximately, than the front tires, and its protected from getting crap stuck in it.
/ Forward Exit Horizontal Exhaust?? #29
I have horizontal forward/side exiting (RK24) and side exiting (NH TD33). Neither has ever bothered me during operation. Both are on the left exiting the side engine panels.
/ Forward Exit Horizontal Exhaust?? #30
Thanks
I am tractor shopping and the reason I asked is the owners manual for my new to me Alamo SHD96 Flail mower says one cannot have an under tractor exhaust that exits to the rear.
Some of the tractors I've looked at have underslung exhaust systems, but I think they could be reversed and run forward. However, I have not run a tractor with a horizontal forward exiting exhaust.
I have a John Deere 1025R that I put an upright pipe on with a flex cap on top and I do have the surround cabin. Before I fixed it up - the exhaust would be down and forward - which heated up the front snowblower in the winter and made quite a mess of re-frozn snow packed in the blower. During the summer with the doors off - I have no problems with the exhaust coming to me.
/ Forward Exit Horizontal Exhaust?? #31
Older gasoline engine tractors were notorious for setting fires, especially if the muffler was removed (it served as a spark arrestor). We had an Allis-Chalmers B that set multiple wagons filled with hay bales afire before we learned our lesson that it's place was on a hay rake, half throttle where it didn't spit out flaming carbon. Dad reluctantly re-installed a muffler on our Farmall H following a couple fires - it was our most common hay hauler in the late 50's early 60's. None of these had horizontal exhausts but the fact is that gasoline engines (and I'm talking of 30's, 40's, & 50's) were notorious fire starters. Diesels run a cooler exhaust because of improved efficiency - more heat is converted to work on a diesel, thus lower exhaust temperature and reduced tendency to start fires. We started our shift to diesels on our farm in 1956 and away went the burning hay wagons. We never had a gas engine tractor with a horizontal exhaust but I assume the same hot spark issue under high power load would exist.
/ Forward Exit Horizontal Exhaust?? #32
I have a forward pointing vertical exhaust on my open station Kubota M6040. Never bothers me. Sorry - just noticed you are asking about horizontal exhausts. I would guess they are not a problem either. But take a look at the picture of mine. Vertical with a tip that directs the exhaust gasses horizontally. Whatever - in use the exhaust gasses are never noticeable. View attachment 694001
I have a 2yo Massy with a horizontal front opening exhaust. Not a problem. Smelled exhaust once in 2 years.
/ Forward Exit Horizontal Exhaust?? #33
We have 2 with the "sideways" pipes--seldom notice the exhaust. You could put an extender on the sideways (or vertical) pipe to deflect the exhaust out further it it's a concern. Diesel smells better than gas, to me, anyway....:)
/ Forward Exit Horizontal Exhaust?? #34
It can very well happen. Mostly with the newer tractors with emissions, when it starts the regen process.
We have had big fires starting because the tractors started the regen process during brush mowing in forests with dry brush.
Regen? Heck, my Mahindra has no such function. Tier IV but no regen, no DEF and no wild fires . . . That's JUST why I bought it - 'cause I was so worried about setting the woods on fire. OK, OK, maybe there have been cases - Like catalytic converters and leaf piles don't mix well. But, regardless, like most things, a little common sense goes a long way: Don't park on piles of leaves, grass, hay, etc.
My tractor has a front exhaust and, when standing in front, sure, the exhaust is noticeable. But, I don't recall it being a problem while operating the tractor. Still, it would be cool to have a nice, shiny chrome exhaust stack with one of those rain caps bobbing up and down. That way, I could see all them sparks flyin' out!
/ Forward Exit Horizontal Exhaust?? #35
I think we're all overlooking the big advantage of vertical exhausts on smallish, no-cab tractors. It's a great hand warmer in the wintertime while removing snow. And adjustable, too. The more heat you like, the lower you grab it.
/ Forward Exit Horizontal Exhaust?? #36
pI have a forward pointing vertical exhaust on my open station Kubota M6040. Never bothers me. Sorry - just noticed you are asking about horizontal exhausts. I would guess they are not a problem either. But take a look at the picture of mine. Vertical with a tip that directs the exhaust gasses horizontally. Whatever - in use the exhaust gasses are never noticeable. View attachment 694001
I just spent a few weeks cleaning out some commercial chicken houses. Move slats, clean poop. Move slats back, then others moved on top of those, clean poop. Then go back and reset the slats back. Used an old tractor with the exhaust broke off at the hood. Never have sinus trouble but I do now. I. can blow a double handful of snot at any time on demand. Been messed up for weeks now. Get the upright exhaust, heat rises. If you're afraid you'll break it, incorporate into some protection. Our skidder has the exhaust in one of the runners from the grille to the top of cab. Can't say it will last, but it was bought new when Jimmy Carter was president.
/ Forward Exit Horizontal Exhaust?? #37
It's not a matter of common sense. You can't predict that the DPF will regen and what happens if you're bailing? Or you're in the middle of high brush mowing? Things can go south very quickly. That's why they put a button there to cancel the regen process, however some people can miss it due to lack of knowledge.
The DPF does get temps above 1200F, so you can imagine how hot the gases at the exhaust will be. Just for the kicks, my dad's SUV was regenning one time and I grabbed a dry leaf and held it 4" away from the exhaust tip. That thing lit on fire almost instantaneously.
Mahindra claims that their tractors don't have regens, I guess this was a nice marketing move as people that don't quite understand the various emissions systems fell for it. However, they use a DOC, which is technically always regenerating/burning once it gets to the proper temperature. That's why it's very important with this system, not to idle too much and run high RPM, so it doesn't plug the DOC. One system is not better than the other and vice versa.
/ Forward Exit Horizontal Exhaust?? #38
We have a JD backhoe with a factory forward exiting exhaust, below the front "grille" area. I do get a whiff of exhaust fumes occasionally, but not really much different from other open station rigs I've used. Now, if it had regen crap on it things could be different.
/ Forward Exit Horizontal Exhaust?? #39
I own a 1959 M-F 50 gasoline that came with a horizontal exha
ust & I converted to vertical do to exhaust fumes using my log splitter & I'm glad I did! If your not using a aft mounted implement that requires to stay at the rear of the tractor while it's running than your okay going horizontal
/ Forward Exit Horizontal Exhaust?? #40
I own a 1959 M-F 50 gasoline that came with a horizontal exhaView attachment 694441View attachment 694442ust & I converted to vertical do to exhaust fumes using my log splitter & I'm glad I did! If your not using a aft mounted implement that requires to stay at the rear of the tractor while it's running than your okay going horizontal
Also on my newer 2018 M-F 1526 it has a mid mount forward exhaust horizontal that there is no problem with exhaust fumes ( diesel )
Skid steer Fork Bracket  (A62679)
Skid steer Fork...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2018 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2018 ROCK SOLID...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
