Chainsaw died;
/ Chainsaw died; #41
Congratulations. I agree, please let us know how you like your new saw. I"m thinking about upgrading this summer and probably will try a Stihl this time around.
I only hope that I'm still able to run a saw when I'm your age. 👍
/ Chainsaw died; #42
Make sure you compare the chain specs. I know the chains and bar from my MS250 won’t work on the MS261 but an unsure if yours will swap or not.
/ Chainsaw died; #43
Congrats, Oddballs. That's a great saw.
Note that it can take a few tanks of gas run through it before the saw really wakes up and makes full power. so you may notice a difference between your first cuts and how it runs down the road (though a dull or poorly-sharpened chain can more than make up the difference between a brad new and a broken in saw.)
There is actually a section in the manual to get the M-Tronic adjusted to optimum power more quickly.
/ Chainsaw died; #44
Heck, I think I have a gauge for some old car engines around here somewhere....but I really don't know much about it other than routine maintenance. I wonder what the compression should be, just in case I get into it. I can see the piston go up/down thru the exhaust/muffler hole. Maybe the piston has rings??? I don't pretend to be much more than shade tree mechanic.
Thanks Mo
First see if it is out of gas. Then pour all the gas out and look in the tank to see if the line is broken. If this is all good go back to the exhaust port. If you can see piston move up and down thru the exhaust port you should be able to see the ring. If the piston is scored, scratches or lines up and down on the piston and across the ring, it got to hot. The cylinder will be scored too causing it to loose compression. If the piston looks good, smooth with no scratches, the cylinder and piston are probably ok. The crank shaft seals could be bad causing a lean condition that could cause it to stop running. You have to do a vacuum and pressure test to check the seals. Sometimes the coil can go bad. You can start the saw and use it and it will run fine but when you shut it off it won't crank until it cools off. The only way to check that is to put a new coil on it. If it fixes it you know the coil was bad. If it doesn't fix it you know the coil was good. Now you have an extra coil. Pulse tube could be leaking causing it to stop running because of lack of gas. Fuel pump diaphragm in carb. could have a hole in it. Also there is a small hole in the cover over the fuel pump diaphragm. Fine dust and dirt can inter the hole and build up over time and the diaphragm can't move enough to pump gas. This is on the bottom of the carb. It has small philips head screws at the four corners of the cover. Remove the cover, gently remove it without moving the diaphragm. Blow the dust out. Remove the diaphragm and blow thru the fuel intake tube while you push down on the needle valve arm opening the valve. If you can't blow through it something has stopped up the needle and seat. Remove the needle, arm, and spring. Then blow it out with carb. cleaner an reassemble. If none of this works buy a new saw.
/ Chainsaw died; #45
That procedure will adjust the M-Tronic more quickly. However, it has no bearing on what I was referring to. Chainsaws do not make full power until they are broken in and the rings seated. It varies from saw to saw, but it usually amounts to getting several tanks of gas run through it to complete the process. This is a separate issue from the tuning of the saw, whether that tuning is done manually or via electronic/computer control.
/ Chainsaw died; #46
Once I had my Echo burned it, brought it to the shop for tuning.
This still leaves warranty on place as he is an Echo dealer, and I get a much better running saw.
CS490 , went form 18" to 20 " and it runs right through ash and cherry. Before with 18" would bog a bit here and there, now, very little bog and I have cut down and bucked some 20+ inch Ash trees.
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
Truck Mounted Carpet Cleaning Extraction Machine (A61166)
Truck Mounted...
