Filled Tires or Ballast Box?
/ Filled Tires or Ballast Box? #1
Git-R-Done
Woodville, TX
2021 JD 1025r (Process Buying)
I have not purchased my 1st SCUT or CUT YET, but am curious. My property is quite sandy for the first 12-16". I will rarely be using the FEL, but have a few projects so mainly mowing. Would it be better to go ballast box for when using FEL. My thoughts are the additional constant weight if fill tires would leave tracks in yard when mowing? What says you?
Git-R-Done
/ Filled Tires or Ballast Box? #2
Git-R-Done
Probably have to ask yourself how many times per year you need to remove it. If you don’t mind swapping the box on and off, that’s what I would do. Maybe a quick hitch on your 3 point would make it faster/easier??
I don’t like liquid filled tires, but if it must go on the wheels, I’d do cast rims and/or wheel weights.
/ Filled Tires or Ballast Box? #3
The ballast box on the iMatch quick hitch is the way to go. The QH makes dropping the box and picking it up again "quick" and easy. Sounds like a perfect "match" for you to Get-R-dun :) whoops! Git-R-done ;)
Good Bill O'Reilly quote.. lol
/ Filled Tires or Ballast Box? #4
I would get a box blade to use as ballast, use it for double duty vs. just a ballast box that only has one job it can do...
Skip the fill tires if you are mainly mowing....
/ Filled Tires or Ballast Box? #5
Git-R-Done
It's not really a "which one" question. A ballast box (i.e. 3-point hitch weight) serves a different purpose than does filled tires or wheel weights. Check the Operator's Manual for the loader that you are thinking about purchasing (available on-line on the JD site). It will outline the specific ballasting requirements for that particular tractor/loader combination to enable it to be used safely.
The dealer said the same thing.
/ Filled Tires or Ballast Box? #7
My ballast box has more than one job.. Grab hooks welded to it for hooking chains up when needed, it is a chain carrier when logging, and other odds n ends that take the place of a handy tool box.
Also dropped to the ground will remove stumps, level high spots, and can dump dirt in low spots.
And it is close in so not catching things that a box blade catches easy.
All in what fits ones' fancy.
Of any attachment that I have that gets little to no action, it is my box blade.
/ Filled Tires or Ballast Box? #8
Git-R-Done
Just fill the tires and use it 24/7. If you need extra weight, throw on a ballast box then remove when job is complete.
/ Filled Tires or Ballast Box? #9
I have filled tires and wish I could lose the weight when early spring and late fall come. Ground gets very soft and wet, and I leave ruts whenever I go on the lawn. I would go with the ballast box so you can run light when you want and add weight when needed.
That's pretty much what I am thinking. My property does the same thing.
/ Filled Tires or Ballast Box? #11
Also consider turf tires instead of R-4's. My father-in-law's New Holland TC29D is about the same size as my tractor and has turfs, and he does much less rutting than I do with my R-4's.
/ Filled Tires or Ballast Box? #12
I just bought a Kubota bx1880, but I haven't received it yet. I also don't plan to do any mowing with it.
When I was looking through my options, I decided to purchase the rear wheel weights for it (they aren't all that expensive). My thoughts were I can remove them when and if I don't need them (although I don't know how difficult a task that is. I keep a good cordless impact wrench around). My dealer encouraged me to fill my tires so I wound up doing that also. I plan to purchase a box blade and keep it on the rear for ballast.
My property is also very sandy.
/ Filled Tires or Ballast Box? #13
I had my CUT tires filled when I bought it, and have never been sorry. It adds some useful weight for any operation. I have ag tires, but little work on lawns, so they are perfect. I carry a box blade on the back all the time because it is invaluable for smoothing my mile long gravel drive. I use the FEL a lot but have never lifted the rear or felt I needed more weight. I am debating some wheel weights just to ease the pucker factor on slopes - or some extenders.
/ Filled Tires or Ballast Box? #14
JMHO - I have rimguard in my rear tires and a rear blade on the 3-point. That's 1550# of rimguard and the rear blade is 1050#. Ballast box is a waste of $$$. Why not put something on the 3-point that has more than one use.
/ Filled Tires or Ballast Box? #15
Go for the ballast box...
Filled tires help with stability, but not so much as ballast. The ballast box best serves as the rear counterweight for loader work and really takes the strain off the front axle
As far as what to use for ballast, I like sand. Although once filled, I've never dumped it out (after at least 10 years), but I can if I want to. Permanent ballast is just that...permanent.
/ Filled Tires or Ballast Box? #16
The manual for a JD will say filled tires AND rear ballast. Filled tires also help with stability.
/ Filled Tires or Ballast Box? #17
Fill the tires see how it handles than decide on ballast box etc.
/ Filled Tires or Ballast Box? #18
I accomplished great stability with 3" spacers on the rear axles. Prior to that, filled tires didn't do the job for me.
/ Filled Tires or Ballast Box? #19
I have just filled tires on my scut for ballast. I have lifted a full bucket of stone without lifting the rear of the tractor or loosing rear traction. I also move this stone driving down my driveway which is going down hill with it. On mine the fill only adds a little over 200# and I don't see me every trying to lift more weight than a bucket full of crush run. As far as weight on my lawn, I have not seen any damage that concerns me, but then again I don't overly concern myself with the lawn beyond it being green.
Filled tires will also add some stability because it lowers COG, maybe not as much as spacers but they have to help at least a bit in addition to my 2" spacers.
/ Filled Tires or Ballast Box? #20
I used my TC33D mainly for mowing so I had turfs. I did not fill the tires as I used my tiller as ballast. I also removed the loader when I wasn't using it. It only took 10min to install/remove it and it made mowing much more enjoyable.
