Thomas
Epic Contributor
- Joined
- Apr 6, 2000
- Messages
- 31,786
- Location
- Lebanon,NH.
- Tractor
- Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
Welcome to GM Weld.man &Blacktruck.
I caught that also.
I do, but that's the trouble: It's down the hill. As in about 1/4 mile and 200' down hill. Could probably paddle one of those plastic kayaks down slope, but I dunno about getting it back up!I believe you have a fairly substantial puddle just down the hill as well, RNG.
Sounds like a good workout in the wood gym, Rick. Perfect for workin' off those holiday pounds and building some muscle tone. It's also a good way to wear out your favorite gloves, rip your shirts, scratch your face, dull a bunch of saw chains, and drop heavy stuff on your toes. DAMHIKT...Three solid days of manual labor. I'm going to try to push over the middle tree with the New Holland then .. a bit more lower limb removal on the other two trees.
Good morning, low temp 36, high 59°F. Wind E 11 mph. Sunny!
Got some nasty news yesterday, the DIL has 3 months to live at most. They (the doctors) are guessing it is cancer. She is bleeding somewhere and they can't tell where. Guessing the small intestine, which normally (if you can call it that) is non operable. She has been in constant pain since 2006. She was on morphine until it made her physically sick even with gravol, so that was the end of that. Tylenol doesn't touch the pain, morphine makes her sick so they gave her something else. The doctors are a little reluctant to shell out Oxycontin.
A town run is in the cards for today.
Have a safe day all
Nope... takes a while to fill all those 'low spots' in the axle. When I had changed mine, did it nice and slow, took it up to the top of the fill hash marks and let it sit overnight. Checked in the morning.... a little lower, but still good. Used it a couple hours and miraculously was 1 1/2 quarts low.....filled it again and has been at the same full mark for the last 6 months.Good afternoon! 84˚F partly cloudy, South wind.
I had a call this morning that the front axel oil on the JD (4WD) was low and the tractor would be out of service. There was no oil showing on the short dipstick on the axel. I changed out the oil a month ago and filled it. I put a screwdriver in the dipstick hole today and determined it was right below the dip stick. There were no leaks. I added a half quart and that filled it up (it holds a gallon). I suspect there must have been a bubble in it or is just filled all the voids after being driving around. I did not check it after driving it when I changed out the oil because it has no filter to fill. Any other explanation?
Often those bevel drive front axles when you drain them from the axle hubs and refill from the upper axle housing.Good afternoon! 84˚F partly cloudy, South wind.
Thank you sir. Happy to be here. Using my tractors around home is my happy place. This is living vicariously through you all until I get there.Welcome blacktruck to GM thread
Pretty much how I see it also. Summer is time to tackle the easy stuff and enjoy the days.This is Fall, Winter, Spring work. Summer .. not so much.![]()
Thank you also for the welcome. Nice to find a forum of like minded individuals.Welcome to GM Weld.man &Blacktruck.![]()
Sounds like a good workout in the wood gym, Rick. Perfect for workin' off those holiday pounds and building some muscle tone. It's also a good way to wear out your favorite gloves, rip your shirts, scratch your face, dull a bunch of saw chains, and drop heavy stuff on your toes. DAMHIKT...![]()
Rick, someone else from tbn just did a YouTube review of your cha ching. Do you get royalties from that?![]()
