New log splitter
/ New log splitter #21
Another Honda lemon. I'm pretty sure these are the only two I've heard of.
Let me add a third.
I have a honda 2000watt converter that starts first pull every time......IF I use it every day.
Let it sit for a month and it takes at least a dozen pulls.
It took 17 pulls last week after sitting covered in a heated garage since last September.
/ New log splitter #22
Let me add a third.
I have the very same issue with my Honda 2000, now it doesn’t want to idle down with no load. No ethanol gas and Sea Foam added.
/ New log splitter
Take a look at the Harbor Freight 2 way splitter. I have the Northern Tool version which is no longer sold. The cylinder is below the work area, so it splits both ways, no retract stroke needed. I had a dual direction 4 way head made for mine which really increases productivity. Mine is a Powerhorse engine and always starts on first or second pull, even after sitting for months. I’ve heard good things about HF’s Predator engines.
I looked closely at that splitter. It's a good design; my only beef with it is the height. It's a bit low, which is hard on the back. I've seen workarounds (blocks under wheels). If it had been on sale, and/or carried in the HF retail store, I probably would have bought it.
I replaced a B&S 6.5 on my Husqvarna tiller with a similar Predator. Runs great. Wouldn't hesitate to use one again.
/ New log splitter #25
This afternoon, bought the TSC County Line 25 ton splitter, along with the optional 4 way wedge and the log cradle.
Not sure I'd want a 4-way wedge. Yeah it might be a little quicker on some pieces, but not every piece needs to be quartered, and some larger ones need more. Seems like it might be more trouble than it's worth unless everything is within a certain diameter range.
/ New log splitter #26
I just bought the Countyline 25 ton splitter from TSC today. The price on my IPAD browser says $999.99. When I was in the area of the TSC I checked to make sure they had one in stock and the price was now $1099.99. I figured bad timing, it went up $100. When I went inside the store the employee looked it up and it was $999.99. Same SKU # but $100 more on my mobile phone.
I am glad I didn’t prepay for it before I got to the store.
It was in the crate but the employee said he would assemble it real quick so opted to have him do it.
/ New log splitter #27
I just looked at another log splitter from TSC - Countyline 30 ton. $1,499.99 on my IPAD browser and $1,699.99 on my phone browser. Same manufacturer part number YLT-016-926.
/ New log splitter #28
I've noticed prices can vary from the 3 TSC stores near me. So I check all 3 before I commit to a larger purchase.
/ New log splitter #29
I've been looking at log splitters, but haven't decided what to do yet so I stopped in at Northern Tools today and looked at their log splitters. They had a really massive one rated at 37 tons. 8 bolts on each side of the slide. Heavy duty beam, large diameter cylinder. I looked more closely and am now confused, so help me out here and tell me what I'm missing:
The cylinder is 4.5" diameter, so 15.9 sq in of surface. Couldn't find the spec for the pressure, but the high pressure hose was rated for 4000 psi, meaning the actual pressure is probably a little less, but I'll use 4000.
Thus 15.9 times 4000 = 63,600# = 31.8 tons.
Where are they getting the 37 tons (74,000#)? The pressure would have to be 74,000/15.9=4654 psi. That's an over pressure of the hose by 15%. What am I missing?
Unfortunately, that's rather common in the log splitter world. I'm not sure how they get away with it, but in years past when I was shopping, I saw more splitters with exaggerated ratings than I did with honest ones. If I had to guess, I'd bet the pressure is below 4000 PSI. Probably 3500 PSI max.
/ New log splitter #30
I have a briggs and Stratton portable generator that starts within 1 to 2 pulls every time. I have a Honda pressure washer that needs 10-12 pulls. Both used about same amount of time. Same age, same maintenance. You tell me
/ New log splitter #31
I have Honda engines on most all my small equipment. I just wonder why others have not adopted whatever Honda does to make their engines superior. Must be covered with some pretty strong patents.
/ New log splitter #32
I was looking at those not long ago, the specs for the 37t list it as a 5in dia cylinder. You sure it was a 4.5?
/ New log splitter #33
Yes. The one I was looking at had 4.5" on the cylinder. If it was 5", then I can see the 37 ton. I'm wondering if they ran out of 5" and just put in 4.5" until they got more 5"?
/ New log splitter #34
I have an older TSC/Huskee splitter that was built by Speeco. It's a 22 ton model, and I chose it because it had the fastest cycle speed too. It's been a great splitter, and the B&S engine starts first pull, every time. Just had it out for the first time in a year, and sure enough it started with the first pull.
I have 3 Honda engines, and at least 2 are the better GX series. They are difficult to start every time. Part of the problem with them is they need over 1/2 throttle to start even when they are hot. Either that or choke every start, warm or cold. I'm used to engines starting with the throttle bumped just above idle, so it's a learning curve for me.
/ New log splitter #35
Marketing. Most people wouldn't know the difference or even how to calculate it. Sort of like stereo equipment in the 70s...some WT Grant stereo with built-in 8 track that's "1000 watts" when it really might be 5% of that at best.
Again, marketing. Charge a premium price and make all your marketing hype about it's "legendary" quality and reliability, after a while people believe the hype. Apple's done quite well with that approach.
Over the years I've had small engines from 'most every maker (including the Chinese stuff), they're all about the same...small differences, but that's about it.
/ New log splitter #36
Mine refused to start once, discovered some idiot hadn't turned the fuel on.
The Honda on my Timberwolf won’t start without the ignition switch turned on which is mounted on the beam side out of sight from normal starting position of the operator.
I know this for a fact.
I’ve tested it many many times unaware....
/ New log splitter
I can verify this with my own testing of these same switches. They reliably prevent starting when in the off position.
/ New log splitter #38
When and why did small engines start having that priming bulb? It never used to be there and for a healthy engine, they always started.
/ New log splitter
I only see them on two strokes.
/ New log splitter #40
I know I have one on my 4 stroke Makita Blower.
2022 CATERPILLAR 914 WHEEL LOADER (A65053)
2022 CATERPILLAR...
213121 (A64276)
213121 (A64276)
2000 NEW HOLLAND 5554 BACK HOE (A66091)
2000 NEW HOLLAND...
2017 Ford F-250 4x4 Crew Cab Pickup Truck. (A64194)
2017 Ford F-250...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
(INOP) GRASSHOPPER FRONT DECK MOWER (A64278)
(INOP) GRASSHOPPER...
