PTO clutch
/ PTO clutch #1
Stevearlott
Zetor Proxima 75
Zetor Proxima 75.Should the PTO clutch lever be in the down position with it in neutral when not in use?Thanks.
/ PTO clutch #3
I don't know your tractor but normally the PTO is disengaged (not spinning) when not in use.
/ PTO clutch #5
Nice tractor!
If you have a PTO lever with 3 positions, than one position is the PTO on engine speed, middle position is PTO in neutral, and one position is PTO on ground speed through the gearbox.
I think if you put the High / Low in neutral, and the gear in reverse, than your PTO runs in reverse. Nice for un-doing a stuck post auger.
You don't have to put the lever in neutral if you don't use the PTO, but you can.
On certain models Zetor tractors the PTO lever also has a position that disengages the hydraulic pump.
If you Google "Zetor Proxima owners manual" you will find some. Look for WWW.cals.cz
/ PTO clutch
Nice tractor!
That’s great thank you
/ PTO clutch #7
If you're asking specifically about the clutch lever for the PTO, it should always be down when the PTO is in neutral. The manual says to leave the clutch lever engaged (raised position) no longer than 15 minutes at a time.
/ PTO clutch
That’s great, thanks
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
4021 (A59228)
4021 (A59228)
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
