Floor mat for L2501?
/ Floor mat for L2501? #1
number two
Northern Lower Michigan
Kubota B3030HSDC Kubota L2501HST
Has anyone added a floor mat of some kind on an L2501?
I'd like to put something over the metal flooring,and I'm not sure how much I would like the bedliner treatment.
Thanks in advance for your comments!
Awesome!
Anyone have his e-mail or contact info?
I'm not on OTT.
Should I be?
Thank you again!
/ Floor mat for L2501? #4
Agreed!
Those look pretty nice! Hadn’t seen them before. I wasn’t planning on floor mats but, these appear promising. Price and contact info would be great.
Mike
/ Floor mat for L2501? #5
Awesome!
I'm not on OTT.
Should I be?
Thank you again!
If you want to be a member of the cool crowd then you should be on OTT! You can still be on TBN too, I am.
/ Floor mat for L2501? #6
I'm not on OTT.
Should I be?
Depends on if you like talking about orange tractors (and mainly only orange!) - there are posts that are in both locations but there are a couple of mechanics that work for Kubota dealers - information that you just don't get here.
They are a nice bunch... you will get banned or censored if you are not nice so if that's an issue with you... tell them mcfarmall sent you!!! :ROFLMAO:
Agreed!
Mike
Text Ken @ 864-633-9664 for the floormats.
Thanks guys! I think I'm signed up there.
Where should I make the first post?
/ Floor mat for L2501? #9
I cleaned my painted steel floor boards, wiped them with acetone, and painted them with truck bed liner about 5-6 years ago. It has held up perfectly, and I am happy with the results. I found a photo showing what I did. It wasn't difficult to do, and well worth the effort, I thought.
I masked off the center cover and sprayed the three strips on it, since I often step on it...
/ Floor mat for L2501? #10
Looks good!
Mike
That does look quite good,Varmint.
I did order the floormats,but may use your idea for the center cover.
Again,thanks for all the replies!
/ Floor mat for L2501? #13
Wanting floor matts for my CUT mainly to retain heat I used those interlocking 1/2" foam matts they sell in many dollar stores.
I simply custom trimmed to fit and voila, insulated floor matts.
Main problem was the matts sold were all different collared but what the hey, warm feet is what it was all about.
/ Floor mat for L2501? #14
Replaced the floor mat on my M9 open station last year. Bought the OEM mat and it was just under 100 bucks, so a cheaper alternative is nice. My issue was it's form fitted (over the center hump) and the OEM mat comes with push pins and has the gear shift selector molded in plus, it's very thick. My cab M9 has insulation under the floor mat from the factory. Never wore it out (mat or insulation layer).
