Gravel for Driveway...
/ Gravel for Driveway... #21
Charles has good advice. (Most notably: expect maintenance and plan for it. A box blade and/or land plane are a must.)
I don't know if it's available to you, but recycled crushed concrete is amazing stuff. It is very "jagged" and locks together extremely well, with 20-30% fines -- the dust creating during the crushing process. The problem is that it'll almost always have some leftover metal in it that the crusher's magnet didn't remove, so you have to deal with that the first year. My current driveway is 5 years old and has needed very little maintenance; something to consider maybe.
/ Gravel for Driveway... #22
The favorite in my area is recycled crushed asphalt or shavings.
Bonus is it costs less than crushed stone (gravel) and hot sun fuses it back to an economical asphalt.
Also great on steep hills as it won't wash out under heavy rains.
/ Gravel for Driveway... #23
Old post but looking to repair a 850 ft driveway and all these terms seem confusing.
I guess gravel (using this as a loose term) has more than doubled since 2009.
I am being quoted $38/ton plus delivery fee.
There's gravel, and then there's gravel.
What are you getting priced on, pea-gravel or what?
Keep shopping, keep learning from your shopping
/ Gravel for Driveway... #24
I found a local guy that delivers by the yd. Will get 12 yds of 1-1/2" pan base for $35/yd + $50 delivery fee.
I also found out that 1 yd = 1-1/2 tons so I will be getting 18 tons for $470 delivered.
This ends up being $23.50/ton versus $38 I was finding on facebook.
/ Gravel for Driveway... #25
Gravel prices are very regional, Live near a gravel pit in a semi-economically depressed area? Almost dirt cheap.
Couple months back, I got 9 -1/2 ton delivered for $132 and change. Too lazy to work out the numbers. What's called dense grade. Maybe some call it road base.
Got like 5 quarries nearby. Less than two miles straight line, but closer to 20 by road. Yeah, our roads curve around a bit.
/ Gravel for Driveway... #26
Should I use 1" or 2" or 3" gravel to get my driveway up to grade.??
Thanks.
Thanks for starting this thread. My 900" driveway needs new gravel. Would like to get a type that packs down and gravel doesn't roll around like marbles. Will be watching this thread closely to try and figure out what to order from local quarry.
/ Gravel for Driveway... #27
Different areas/quarries have different terms. You can buy 1", 2", 3" rock - it's washed no dust. They sell the dust as Ag Lime. The CA# products are crushed aggregate - dusty. CA6/CA10 refers to the screen sizes. to big for .6" screen falls through 1" screen often called road pack by a home owner who's never visited the quarry.
Outdoors with the morgans has some videos on building new drives.
/ Gravel for Driveway... #28
I just had 84.4 tons delivered and spread to top dress my 1/2 mile driveway. $2,600, four truck loads. Special driveway mix of high population of 3/4, 1/2 with some base fines. Higher compaction strength than base or #57. Have 300’ elevation change winding thru the woods. With continuing improvements to grade and drainage hope this to last 20 years. Land plane easily pays for itself in gravel saved, surface durability and maintenance time.
/ Gravel for Driveway... #29
Around here most use what is called 3/4 minus rock for driveway use on the top coat.
/ Gravel for Driveway... #30
Interesting takes from around the country. Here we use #57 granite gravel as a base, then follow up with crush & run. The combination turns into a very hard surface which resists potholes and erosion. Proper crowning required, of course.
Hustler super Z zero turn (A56859)
Hustler super Z...
2025 Miva VA13 (A60463)
2025 Miva VA13...
2022 John Deere R4023 (A60462)
2022 John Deere...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
WATER TRAILER (A58214)
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
