3rd function valve kit
/ 3rd function valve kit #1
Bagley374
Cabelas LM43H
Looking for information regarding a third function hydraulic valve kit for a Cabelas Lm43h tractor having a Woods 102D loader. I need to install valve kit in order to attach and operate a root grapple. Tractor was manufactured by TYM. Any information would be greatly appreciated!
/ 3rd function valve kit #2
I have the WR Long 3rd function valve. Has been great for seven years now. Controls my rock/root grapple - Land Pride SGC1560.
Kit manufacturer, model number specific? Can’t find a cross match kit between tractor and loader!
No one seems to be able to reference tractor and loader combo to come up with a valve kit!
/ 3rd function valve kit #6
Sometimes you just have to plow new ground. Buy a 3rd function kit compatible with your tractor then get any additional fittings or different hoses required to fit the loader.
You're experiencing part of the charm of a low production number tractor fitted with an aftermarket loader. Off the shelf solutions sometimes don't exist.
Agreed, this will probably be the route I have to take, however I can’t find any info on what valve system will match tractor! I’ll keep researching but thinking this isn’t going to be a simple issue to solve! Thanks for your comment!
/ 3rd function valve kit #10
Can you determine what TYM model was rebadged by Cabela's? It's not like TYM designed a clean sheet tractor line for sale at a sporting goods store. A 3rd function kit for a specific TYM (or maybe even a sister Mahindra) model might be an easier find.
That is exactly what I’m looking for! For whatever reason no can or cares to cross reference this tractor and come up with a valve system I can use. I’m sending a TYM dealer serial numbers etc... to see if they can help!
/ 3rd function valve kit #12
The everything attachments third function kit will work on your tractor.
Your tractor hydraulics has less than 10 gallons per minute flow and the kit is good for anything 15 gpm and below.
Waiting to hear from EA attachments, they aren’t responded, what valve kit if you know will work with my tractor!?
Haven’t responded and having difficulty navigating their website, with that if you have any info I could research or cross reference it would be appreciated! Thanks
/ 3rd function valve kit #15
A valve like this will work i’m not saying this exact one, the main thing you need to know is if your hydraulic system is open center or closed center.
Ok.... thinking I need to build mine own system, I’ll have to find someone to do this as I haven’t he means, I was looking for a complete kit to attach into existing system and go from there!
/ 3rd function valve kit #17
I would recommended going with a summit universal 3rd function kit then all you will have to do is measure/have lines made and figure out where to mount the valve
/ 3rd function valve kit #18
Looks like those Cabella tractors were a *******. Tractor Data shows them having a Perkins engine. The only other TYM tractors with a 43 HP engine used Yanmar and Kubota.
Good luck with your search but I suggest a generic diverter kit. Those are pretty easy to configure. I used a DSV-62-08-12 selector valve on my John Deere with a handful of adapters and a momentary switch I was all in for less than $300.
Thanks for your input!
Wooden Wagon Wheel Bench (A61569)
Wooden Wagon Wheel...
2005 Blue Bird BB Handicap Bus, VIN # 1BAKBCKA45F219634 (A61165)
2005 Blue Bird BB...
2025 Swict 72in. Bucket Skid Steer Attachment (A61567)
2025 Swict 72in...
New/Unused Wolverine Quick Attach Trencher (A61166)
New/Unused...
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
