What Do You Do With Your Waste Oil?
   / What Do You Do With Your Waste Oil? #11
It goes back into the 2 gallon jugs it came out of and then I take them to the local O'Reilly's, Autozone etc. Sometimes they enforce the 5 gallon limit, most times not. My 20 gallon HF oil drain dolly is about full, time to fill some oil jugs!
   / What Do You Do With Your Waste Oil? #12
I drop it off at Walmart, Auto Zone, Advance Auto, etc.
   / What Do You Do With Your Waste Oil? #14
Where does the oil go ? Landfill ?
   / What Do You Do With Your Waste Oil? #15
Picked up by jobber and either rerefined or sold to many businesses the can use it, it does not go into ground.... Locally there is a steam excursion rail line that burns the oil to heat their boilers...
   / What Do You Do With Your Waste Oil? #16
I store mine in wide mouthed 5 gallon firefighting foam containers, then take them to the county recycling center in my area. They have a 5 gallon limit.
I believe most states require places that sell oil to accept waste oil, but I've never tested that here in Maryland. The shops that use the waste oil for heat that I have talked to will take oil, but don't allow me to pour it in due to concerns that have been mentioned above. I'm not leaving my containers.
   / What Do You Do With Your Waste Oil? #17
I recycle it unless I use it to start my slash pile burns in the spring with it, motor oil and sawdust are good slash pile starters without the danger of explosive effect like gasoline.
   / What Do You Do With Your Waste Oil? #18
I drop mine off at a local garage that has uses a waste oil furnace for heat.
   / What Do You Do With Your Waste Oil? #19
All the numerous county funded recycling centers around here take it for free. Most of the automotive repair places have waste oil heaters so I’m guessing they would take it.
   / What Do You Do With Your Waste Oil? #20
My understanding is it has some value. I’m not sure what they do with it but I think it was Valvoline was advertising there was a “green oil” that was using some percentage of recycled oil.
2013 Nissan Sentra Sedan (A56859)
2013 Nissan Sentra...
2019 Berky Weedo Amphi King 6450 Amphibious Workboat (A56857)
2019 Berky Weedo...
Blue Diamond 103709 (A53317)
Blue Diamond...
2022 Chevrolet Express (A57148)
2022 Chevrolet...
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
1325 (A58374)
1325 (A58374)
