Chain Attachment Point
/ Chain Attachment Point #1
Sweetwater, TN
RK55HC
I want to pull out a large shrub with a 3-inch trunk. I have a shrub grubber chain and Grade 43 3/8-inch chain. I know to throw a blanket over the chain. Is the best attachment point to the tractor to hook the chain around the swing drawbar pin?
/ Chain Attachment Point #2
Do you mean the 3 pt lower link arm? That usually swings. The Drawbar is usually stationary with a bunch of holes in it for mounting hitch balls, etc.
I actually meant the drawbar. Is that the strongest attachment for a chain? How should you best attach the chain to the tractor?
I had one. Hook the chain over the red bolt?
/ Chain Attachment Point #7
Does RK have front loader? if so did you loosen dirt around shrub for easier pull
It does, but I can't get access across a ditch and dense pines around the back. I can loosen dirt first with a shovel. Thanks for the advice.
/ Chain Attachment Point #13
Hooking on to the clevis is fine but as pictured above it really isn’t needed. Just hook the chain around the pin that the clevis is hooked to.
Many people just have drawbars with a single bar and hole and a clevis makes for a good way to attach a chain.
The drawbar is the best place to connect a pulled load. It is what it is designed for. The drawbar is mounted below the centerline of the axle. This is a safe place to attach loads. Attaching above the centerline of the axle can cause the tractor to flip over backwards.
UNUSED SDLANCH SDLGC100 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
2013 ISUZU NQR 4X2 REFRIGERATED BOX (A59909)
2013 ISUZU NQR 4X2...
2019 Kuhn GMD3151TL Disk Mower (A63116)
2019 Kuhn...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
Snap-On Zeus Diagnostic Machine (A63118)
Snap-On Zeus...
