npalen
Elite Member
Rent a tree spade.
truck in dirt and backfill.My property was previously a tree farm and I have over a hundred holes where the trees were dug out, balled, and burlapped. I tried filling the holes with my Kubota L4330, but I made very little progress scraping off surrounding dirt and using that as fill. I've also tried loosening up dirt with a tiller, but that is only slightly more effective.
What type of equipment is usually used to fill holes left when removing trees? Should I rent a dozer? Or is an excavator more efficient at this task? If an excavator, is a Bobcat E-85 (20k pound machine; 36-inch bucket) big enough to get through that many holes in an 8-hour rental period?
Or should I just truck in some fill dirt and rent a backhoe?
That would be a lot of dirt to move with an FEL. A dump truck and back up to each hole and then a bigger loader - not a compact - or dozer to level them out.I assume I can move the dirt with the tractor's FEL. The distance between the hole/dirt pile and various holes is at most 500 feet.
That is super cheap if you are talking semi and not tandem and cheap even for a tandem. Around here you are going to pay $100 minimum just for the trucking plus the cost of whatever you want hauled. Granted dirt is cheap but the people digging it up and loading it want something for their efforts.
Regardless I think OP is far better off trucking in material than trying to dig it up to fill these holes unless he already had a backhoe or excavator and a means to haul the dirt.
You can move dirt a lot faster with less wear and tear when you put the dirt into a dump truck and move it.
I watched my farm neighbor start to move a lot of dirt after regrading the fields. I'm laughing at them using an excavator to pile dirt and have the back hoe move it one bucket at a time. I stopped them and asked them how long it was going to take? The reply was forever. Told them to get a truck, even a 6 wheel 1 ton moves dirt a lot faster than what they were doing and for a lot less money.
WOW, that will take a lot of fill to do 100 holes. That would take 100 yards (100 tons) of topsoil. Out of curiosity, they must have been humongous trees when taken out.My property was previously a tree farm and I have over a hundred holes where the trees were dug out, balled, and burlapped. I tried filling the holes with my Kubota L4330, but I made very little progress scraping off surrounding dirt and using that as fill. I've also tried loosening up dirt with a tiller, but that is only slightly more effective.
Another note. I tried using a disk harrow to till all the soil, followed by an 8' rototiller, then a blade. This appears to look good, but after one winter, everything compressed and I still had seriously deep holes.My property was previously a tree farm and I have over a hundred holes where the trees were dug out, balled, and burlapped. I tried filling the holes with my Kubota L4330, but I made very little progress scraping off surrounding dirt and using that as fill. I've also tried loosening up dirt with a tiller, but that is only slightly more effective.
In answer to your 8 hrs rental on an E-85–if you are an experienced operator, maybe to get the soil volume you will need, but I doubt it. Since you mention tenting a backhoe, I assume for your digging you will be renting regardless, so I would recommend rent a excavator, my rationale here is in moving the equipment. With a backhoe, you have a bucket and 2 outriggers to deal with versus 1 blade on the excavator. My $0.02!My property was previously a tree farm and I have over a hundred holes where the trees were dug out, balled, and burlapped. I tried filling the holes with my Kubota L4330, but I made very little progress scraping off surrounding dirt and using that as fill. I've also tried loosening up dirt with a tiller, but that is only slightly more effective.
You cannot make dirt to replace dirt that has been removed by digging the surrounding areas. An excavator or backhoe won’t be much help unless gou already have one. I think your best bet is to use the dirt from the trenches you plan to dig and use a dump trailer and your existing FEL to donthe job.My property was previously a tree farm and I have over a hundred holes where the trees were dug out, balled, and burlapped. I tried filling the holes with my Kubota L4330, but I made very little progress scraping off surrounding dirt and using that as fill. I've also tried loosening up dirt with a tiller, but that is only slightly more effective.
