Leaving Implements Raised - Bad For Hydraulic System?
   / Leaving Implements Raised - Bad For Hydraulic System? #41
I've never seen an unloaded seal fail.
   / Leaving Implements Raised - Bad For Hydraulic System? #42
How or why would it be bad for the hydraulics? The pump isn't running so there's less/no pressure other than the weight of the implement. There can't possibly be any more stress put on the cylinders than when lifting an implement or digging with the FEL. 10 times out of 9, hydraulic failures are due to lack of maintenance or operator error. The only true issue with lifted implements is the safety factor. I pull things with my chain on the draw bar sometimes, and the box blade is still on, too. Can't put it down with the chain connected to something, can I? Just don't put any of your body parts under anything lifted. I do much the same, leaving the engine idling for a quick off-tractor task, and shut it down if I'm going to be a while. If I've been digging stumps, I'll typically have one in the bucket, and the bucket tipped back and raised up so I can pick out roots and stuff, toss 'em in the bucket, and get it all done in one trip (obviously depending on the size of the stump and how many roots I pick up.)
   / Leaving Implements Raised - Bad For Hydraulic System? #43
I don’t drop the rear implement when I’m still working because I forgot to raise it and drag it. There’s plenty of times when the need arises to leave the FEL in the air. But I always lower everything when I’m done for the day.
   / Leaving Implements Raised - Bad For Hydraulic System? #44
My first tractor - brand new Ford 1700 4WD. 27 years of use and the hydraulics were still in great shape. Never had to replace a hose or any seal.
   / Leaving Implements Raised - Bad For Hydraulic System? #46
Technically, every material is subject to plastic deformation under static stress. Imagine a gantry crane made of modeling clay; it might look fine before bed, but in the morning it's going to be bent over kissing the ground. Now imagine a gantry crane made of nylon. It would probably look just fine in the morning but wait a year and it will probably be sagging a few inches lower than it used to. Now an ordinary steel one. After 10 million years it would be sagging too (but it would be rusted to dust way before then). Hoses and seals subjected to constant pressure can "technically" be expected to experience more dimensional creep than those not subjected to them.
Practically though, static stress doesn't cause fatigue; movement (dynamic stress) does*. Practically, hoses and seals are going to fail from chemical breakdown of the rubber composites long before they have even a measurable amount of dimensional creep.
And, practically, exposed rods rust faster than those surrounded by hydraulic fluid, so for that reason (as well as safety) I retract everything as far as possible. I don't like that my FEL bucket bleeds down to expose 5" of rod. The mere fact of being located on the surface of planet earth is orders of magnitude more damaging to the system than being left unpowered under pressure.
* Google "static fatigue" for more information. Every practical study I can find on the topic, focuses on the failure of components subjected a combination of static and dynamic stresses, and the static component is only examined in the context that it contributes to dynamic fatigue.
   / Leaving Implements Raised - Bad For Hydraulic System? #47
well I think that the load would be mostly on the piston seals and linkages, short term not much of an issue. One thing I have noticed with my MF 35 is that if you leave the 3pt arms up and turn off the engine, the arms will slowly lower over time and when you go to start up again, unless you remember to put the hydraulic lever in the down position, the starter motor has to also operate the pump, placing an unnecessary load on it- especially if you have an implement hitched up?
   / Leaving Implements Raised - Bad For Hydraulic System? #49
That doesn't work for backhoe though. Can't have both swivel cylinders retracted and to have the dipper cylinder retracted, my backhoe bucket would be pointed at the sky. What's a guy to do in these cases?
   / Leaving Implements Raised - Bad For Hydraulic System? #50
I don't have a backhoe, never had to consider it. But I think I would swing it all the way to the left when I park it. The right one can be the sacrificial lamb. No point in exposing them both to the elements.
LOT: Clevis Hook, Snatch Block (A59076)
LOT: Clevis Hook...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
LOT OF PIGEON HOLE CABINETS (A52708)
LOT OF PIGEON HOLE...
2014 Nissan Sentra Sedan (A56859)
2014 Nissan Sentra...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
