So, what happens to the grease?
/ So, what happens to the grease? #1
jezreel
Eustace, TX
Kubota - MX5400 DTC
I know it’s a stupid question, but. . . What the heck happens to all that grease I pump into that tractor? It doesn’t drip out, or leak. Does it just evaporate? I mean, I gotta tell ya. . . I hate having to grease that thing so often. It shouldn’t be a pain in the butt, but it is. It’s gotta be done, so I do it. I just don’t know where it all goes.
/ So, what happens to the grease? #2
Not a stupid question at all... it's just something that I've never considered.
Other than some of it leaping onto my clothing, I just assumed that it disappeared into the 'never-never'.
/ So, what happens to the grease? #3
Interesting if you're regular with greasing...how much if it ends up as grease spots all over the tractor! (Especially when it's hot out.)
/ So, what happens to the grease? #4
I am guess I am one those odd people. I actually do not mind greasing my tractor but I also enjoy cleaning guns. It just seems satisfying.
/ So, what happens to the grease? #5
I remember reading that over time, the grease, it sort of breaks down and is slowly liquefied, dropping out of the area that was originally greased. Thus requiring a new greasing to maintain lubrication. This process is greatly reduced with the new synthetic lubricants.
/ So, what happens to the grease? #6
I don't know where yours is going, but mine oozes out of every gap and ends up on my clothes!
/ So, what happens to the grease? #7
Depends. Use the tractor a lot and it gets squeezed out all kinds of places. Use it not so much and it seems to turn into powder and blow away.
I pump enough grease in there to see it just oozing out at some of the joints. When I put more grease in, I pump 3-6 times before I see the grease oozing again. And those spots never seem to get bigger between greasing. I don’t know.
/ So, what happens to the grease? #9
I don't know but I just started to clean my new to me Kioti tractor (first day in a while that it's above 10C here!) and it even has grease on the ROPS!
/ So, what happens to the grease? #10
I think as you move the item very small amounts ooze out of the joints, dirt collects, and it dries and falls off.
Ahhhhhh. . . Yeah, that sounds reasonable.
/ So, what happens to the grease? #12
. . . I hate having to grease that thing so often. It shouldn’t be a pain in the butt, but it is. It’s gotta be done, so I do it...
Since I bought one of these:
I dont mind greasing at all. It used to be a real chore using a fitting which had to screwed on & off for every grease nipple (zerk?), especially as your hands got greasy, but this quick attach is so, well, quick and grease-tight.
Couple that with a good grease gun (mine's a Macnaught K29) and at the end of a session, you find yourself looking for something, anything, else to squirt some grease into! :giggle:
(There's a few different quick connects available, but the one in the pic was the first one I saw)
/ So, what happens to the grease? #13
I have one of those too! Great tool/fitting to have on the gun.
OP: Good question. I’ve been wondering the same thing myself...
Mike
/ So, what happens to the grease? #14
Some of it must end up on the bottom of my boot because there is a greasy trail from the back door to the refrigerator.
gg
/ So, what happens to the grease? #15
Here is where the grease is going on my JD 2720 where the linkage passes through the tunnel.
/ So, what happens to the grease? #16
Concur with the Lock and Lube making the job less of a grumble.
Using the longer fitting, which works with all the zerks on the Kubota, makes it easier to reach those recessed on the main arms of the FEL.
And I'm positive the grease which squeezes out does not fall to the ground...
...it only falls on the tractor!!!
/ So, what happens to the grease? #17
Grease is oil and soap to keep it where you apply it. If you hang your grease guns on a nail on the wall of your shop, in the summer time you notice you always have a drop of oil on the plunger handle and an oily mess under where you hang them. The oil leaks out over time, or evaporates and the soap gets rubbed off, or just falls off.
My big grease consumers are front axle king pins on my old greaseable Fords. Seems that every time I think it's been awhile since I greased the tractor, the kingpins take between 10-20 pumps of grease, and yes there is this blob of soap and dirt left where the grease oozed out the last time I greased them.
/ So, what happens to the grease? #18
I read somewhere that this is the proper technique. Supposedly the old grease is what is being pushed out.
MoKelly
/ So, what happens to the grease? #19
Man.... is my tractor the only so obviously building up a full layer of old grease? lol. It's everywhere, especially near all the loader pins. I keep trying to ignore it, but a full clean up will be required soon, probably take a whole roll of paper towels to get it off.
On other points, steering, etc, much is probably rubbed off or falls off in the woods here and there.
yep, I noticed on Amazon there are 2 sizes. They have an XL size that in the picture showed to be about 5.5“ in overall length. Is that the one you’re talking about. And I can see that helping on some of the loader arm points.
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
KUBOTA RTV900 UTV (A62130)
KUBOTA RTV900 UTV...
iDrive TDS-2010H...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2018 FREIGHTLINER M2 4X2 26FT NON CDL BOX TRUCK (A59906)
2018 FREIGHTLINER...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
