Electric Winch for pulling logs/river debris after floods
/ Electric Winch for pulling logs/river debris after floods #21
thanks, I will plan on rope to be tied to a chain that's tied to a log I pull, minimizing rope damage. I have a number of chains, but pulleys are rope friendly and will allow me to pull the log into direction I want. I will avoid cable due to drawbacks outlined until I feel one is a must.
The ropes I looked at yesterday at 3/8 were all almost exclusively made for winches and maxing out at 100ft. I'll take a look at 1/2, if there are any specific ones anybody would recommend, I'd appreciate, I didn't realize it's such a specialty item (or I can't search)
btw, I liked the portable winch, but for a few hundred more one can find a used skidding PTO winch.
Go to commercial rope supplier who cover broad markets, winch rope are very limited in length due to spool capacity... Commercial uses of some ropes are thousands of feet long.... You should be able to order any length you want....
Dale
/ Electric Winch for pulling logs/river debris after floods #22
The best tool for this is a 3 Pt hitch powered logging winch.
I would think that would be a poor idea. The 3 point hitch isnt designed for extreme dead pulls or side pulls either.
Lots of members have stories of broken tractors at the 3 point.
it would be much better on a drawbar connected to the rear axle. Even that has its limits
Best suggestion would be fabricating some sort of a frame pull
/ Electric Winch for pulling logs/river debris after floods #23
A 3 point winch does NOT winch putting the load on the 3 point. It has a blade on the bottom that anchors itself, so the winch is pulling on itself. All the tractor does, is sit there and run the PTO.
Yes, when actually moving the log once winched to it, the tractor 3 point does pull the load, but if you have a wimpy tractor, just pull one log at a time. Also the winch has lifted one end of the log making it easier to pull. The actual winching is the hardest pull, so really it's not so bad pulling a log with the 3 point.
SR
/ Electric Winch for pulling logs/river debris after floods #24
I'd like to consider rope/cable and snatch blocks, and pulling with tractor.
I see bull ropes used by arborist with high ratings llike 40K lb
But snatch blocks seem to be geared towards steel cables, which seem to have lower rating.
Will try to figure out how to do it with a 3/4 bull rope, the 3/4 snatch blocks seem rather pricey thou.
Edit: looks like I was overthinking it, maybe a 1/4" wire rope will be sufficient.
I never used hi-tech ropes because I never had any. Just good wire cables. I started out with 100' of 3/8" cable and could pull and tug on big dually truck stopping trees and never had a break in 30 years. It is an armful and all I would want to carry into a woods.
I also bought a 50' 3/8" and also a 100' 5/16" steel cable. My favorite one to use is the 5\16" cable. It will still stop my pickup truck or my 45 HP loaded tractor with no fails. The are fairly inexpensive. For storing, make a roll and hang them up and forget about them. i seldom wear gloves but should as my long 3/8 cable has a couple burs to watch out for.
/ Electric Winch for pulling logs/river debris after floods #25
I prefer single braid to the twisted strand type rope (but that's just my preference - others may feel differently). It's also a better option if you ever to try one of those capstan winches. Climbing rope like what rock climbers use is incredibly strong, but not really appropriate for skidding logs: it's designed to stretch to absorb the shock of a fall, but that stretch is a serious problem if the rope breaks. A couple of good brands: Sampson and ArborMax make some good ropes for use as winch lines. There are other brands, but I don't recall them off the top of my head. Here is a link to a search on Bailey's. I'm not saying this is the best place to buy them, but it will give you and idea: Bailey's winch lines
If you can find a good used logging winch, that's certainly something to consider. If it's not beat to death and you actually CAN find one for only "a few hundred more" than the portable capstan winch, jump on it right on the spot (I mean like: call your buddy have him run to the bank for you to get the money, and don't let it out of your sight). Once someone gets one, they rarely let them go. In the rare event they do, they are typically looking for almost as much as the new price (and they generally get it). I looked for more than 5 years for a used logging winch in my size range. The only one I found was about 3 hours away. It was badly mangled and barely functional, and an older model Farmi for which parts were no longer available. They were asking about 80% of what a new Farmi 351 sold for at the time (the closest current model Farmi was selling). I passed on it. They did eventually sell it for only slightly less than their asking price
/ Electric Winch for pulling logs/river debris after floods #26
Another good way to store them (if the cable diameter is not too big): coil them up inside an old ATV tire (I like the larger diameter, narrower width tires). The tire can be hung up on the wall, and taken down and thrown in the back of your truck, trailer, or tractor bucket. It helps
[/QUOTE] i seldom wear gloves but should as my long 3/8 cable has a couple burs to watch out for.[/QUOTE]
I got sliced once. That was enough for me.
/ Electric Winch for pulling logs/river debris after floods #27
I am not yet ready for a logging winch, but I'll keen an eye out for a used one.. they don't seem to depreciate too much
I have been heating with wood since 1993. I finally purchases a logging winch in 2018 and wish I would have bought one sooner. A logging winch is like a farmers combine; you won't use it all the time, but when you need it nothing else will really do. You already said you have a recurring, ongoing need to move logs. When you see discussions regarding logging winches I can't recall anyone regretting buying one. I would recommend revisiting the idea of getting a logging winch.
Doug in SW IA
/ Electric Winch for pulling logs/river debris after floods #28
Doug in SW IA
I will 2nd this, having heated with wood for 40 years and only bought a pto winch last year.
After all those years of using all my chains and cables to reach trees in my woods, it is now a breeze and fun.
I lucked out and found a used Norse 450 locally for a reasonable price.
I have not used it much yet as I generally have 2 years worth of logs in my firewood pile.
Well, I almost bought a forestry winch, but after deciding on a model (Hud-son) I learned they don't have any.
I suspect forestry winches are a hot item this year, as I think there will be an oversupply of people making lumber this year.
Maybe I'll pick one up on the cheap in a year or two if I still need one.
So I revisited this thread, and leaning towards a Capstan (edited for typo) winch
1) it's light
2) I don't have to take off my backhoe, which works really well as a counter-weight to heavy boulders and logs I carry with a grapple
3) it gives a bit more flexibility on winch placement (vs where tractor can go)
4) its limits on capacity (2200lb) can be addressed with pulleys
5) it's half the price
6) it's available
7) it uses rope vs steel cable, which is probably work out good for my hands
8) can probably be used where tractor can't get to, and outside of my area where I use the tractor
the only con I see is that it's slower than most PTO/forestry winches, but I think I can live with that.
/ Electric Winch for pulling logs/river debris after floods #30
I loaded some heavy concrete steps onto a trailer a while ago wih a cheapie 2000# winch doubled up. Every inch that it got closer to being properly on the trailer was an accomplishment and closer to the goal, so speed was of no concern. Just happy to get it there. Or unstuck as the case may be.
Oh, and winches don't like stuff that's not on wheels much. I found some sprinkler pipe in a dumpster to use as rollers for my steps.
/ Electric Winch for pulling logs/river debris after floods #31
This will allow you to pull materials without the worry of overheating nor batteries. Good control as you are pulling. Little maintenance and moderately priced.
I used a larger version when I worked on the oil rig and it is amazing what it will do for you.
/ Electric Winch for pulling logs/river debris after floods #32
If you don't have some type hydraulic power ports on your tractor, Gee Ray's contribution will get expensive.
Forget the electric winch. If you do not plan on any logging beyond your stream side, I wouldn't invest in a pro logging winch either.
John Mc already gave you very good solution and that is the capstan winch. Any rope length, 2200 lbs of pull , relatively quick and powered by its own engine.
Not a large investment for what you want to do. Portable Winch Co. PCW5000 2200-lb. Gas-powered Portable Capstan Winch$1,595.99Sportsman's Guide
/ Electric Winch for pulling logs/river debris after floods #33
50' of this with a chain attached at the end with a grab hook will do a lot of work. I've used this method extensively logging in dense woods.
/ Electric Winch for pulling logs/river debris after floods #34
So I revisited this thread, and leaning towards a Sapsan winch
1) it's light
6) it's available
A "Sapsan" winch? Is that a typo for "capstan" winch?
Are you considering something like what was linked in post #14? I don't own one myself, but have used one on several occasions. They can really come in handy.
Capstan is what I meant.. and yes, I am getting from Sportsman's Guide, they seem to have the best deal.
Edited/fixed earlier typo.
Yay.. I'll share results later.
  • Portable Winch Co. PCA-1269 Tree Mount Winch Anchor with Strap
    Current Price:$112.49
  • Portable Winch Co. PCW5000-FK Portable Gas-Powered Winch Forestry Kit
    Current Price:$1,808.96
  • Coupon
    -$20.00
  • WV Sales Tax:
    $115.29
  • Package Protection:
    $0.99
  • Total:
    Current Price:$2,017.73
The Norwood is cool.. It may have been suggested earlier, not sure how I missed it.
I especially like the price! (and I do have hydraulics in the back for the backhoe)
I think the con of it is due to it's light weight, I won't be able to haul anything with the grapple, and would have to skid whatever I pull, not a good option for me as I need to minimize dragging and tear up turf. The pro is probably it can do more than the portable one.
/ Electric Winch for pulling logs/river debris after floods #37
  • Coupon
    -$20.00
  • WV Sales Tax:
    $115.29
    $0.99
  • Total:
I am interested in your feelings on this when you receive it and get use on it. I have a lot of downed ash that I can't drive up to with my tractor to haul out. This could be used multiple times if needed to, to get it oriented correctly. I wonder why the price difference from arrow's above post? Thanks, Jon
/ Electric Winch for pulling logs/river debris after floods #38
At 2,200 pounds pull you will probably skid you tractor if something get hung up or you tie onto something to heavy....
Dale
I got a forestry kit (comes with a few accessories, which is about $400 standalone, or you can get it bundled with the winch), and I got SG member discount. If you're an SG member works out very well compared to Amazon, etc.
/ Electric Winch for pulling logs/river debris after floods #40
I too am exploring practical reasonably priced winches for moving logs. As stated, low duty cycle is a drawback with battery powered electrics. I just stumbled on hydraulic winches that run off a vehicle's power steering pump. Has anyone here had experience with these and do you think they'd hold up moving logs?
One of many I saw on Amazon is below.
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A61307)
Snap-On Gold Medal...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2015 Kia Sedona Van (A61569)
2015 Kia Sedona...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A61307)
2008 Ford F-250...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
