3-Point Hitch Fabrication of 3 Point Hitch Photos
/ Fabrication of 3 Point Hitch Photos
Still waiting on the keyways to be cut. Will post final pics hipefully soon.
/ Fabrication of 3 Point Hitch Photos #22
gt14,
It looks fantastic ! Can't wait to see the final product !
I still haven't finished the 3 PH. I will work on it this winter after football season. Since I coach high school football I have no time for anything but family and football. I also had my tractor rebuilt this summers it is running great now.
/ Fabrication of 3 Point Hitch Photos #26
Now this is a resurrection of the dead. Looking forward to your pictures. :thumbsup:
Ok here are some pics of what I have done. Years ago a forum member sent me a pic of the schematic. I used these to figure out a way to fabricate the hitch.
I started by using pillow block bearings to bolt onto the hitch of the tractor. I used a 3/4 round rod with a keyway as the shaft.
Next I had my high school use Cad to draw the lift arms then laser cut these parts. I then welded these lift arms to weld on hubs and attached to the round rod to lock in place.
What I wish I had was the part numbers for the 3 point hitch for the GT-14 or YM-146. I know some parts are still available, I just dont know the numbers.
/ Fabrication of 3 Point Hitch Photos #29
This thread is way before my time on TBN, but it was interesting to read through. Your fabrication looks pretty good Gt14. As for part numbers I know Hoye has a parts manual. Maybe give Aaron a call and see if he can help you with the parts or part numbers you are looking for.
/ Fabrication of 3 Point Hitch Photos #30
I know, bringing a dead thread back to life. Would you happen to remember any of your measurements from your project? I recently acquired a ym146 and have a bunch of cat 0 attachments I'd like to be able to use with this tractor and have had no luck sourcing a 3pt, or getting any dimensions to fab one up.
Thanks.
/ Fabrication of 3 Point Hitch Photos #31
Thanks.
Search for a tractor junk (recycle) yard in your area. Might find one you could adapt.
/ Fabrication of 3 Point Hitch Photos #32
Thanks.
YM146 CAT-0 OE hardware . . . (click to make BIGGER)
More here:
twentywheels.com/view/3654-yanmar_ym146_diesel_garden_tractor.html
And a close up from all the searches done . . .
AND call and ask IF this kit here would FIT AND WORK TOO !
/ Fabrication of 3 Point Hitch Photos #33
hi i have been trying to figure out how long the factor rocker arm flag brackets needs to be, from center of rocker shaft down to pushrod link hole that the pin goes thru. then how far is the hole center to center on the flags that point aft? also are those oriented exactly 90 degrees from each other? i really need to know this so i can drill my hole with correct mechanical advantage. ym146 of coarse
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2015 Dodge Journey Van (A59231)
2015 Dodge Journey...
2012 International 4300 Reefer Truck (A61306)
2012 International...
2017 Ram 5500 Bucket Truck (A61306)
2017 Ram 5500...
2016 Troy-Bilt 18in. Push Mower (A60352)
2016 Troy-Bilt...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
