3-Point Hitch Fabrication of 3 Point Hitch Photos
   / Fabrication of 3 Point Hitch Photos #11
nice work, beautiful welds. i can't do anything that nice with flux core mig!!! your tractor looks exactly like my john deere 420 from the rear. a 3PH kit for it runs about $300-400. yours looks beefier though.
Yes I still need to weld a little piece to the lift arms that I can attach my sway chains to. I already have the sway chain mount right behind the standard hitch. I also may need to put a bend in the lift arms. My cat ) attachments have a 20" width where they attach to the arms. /forums/images/graemlins/laugh.gif
   / Fabrication of 3 Point Hitch Photos #13
Nice project and very nice implementation and workmanship.
What kind of implements do you have in mind for use on the tractor?
I have a nice little grader that flips to turn into a ripper or a plow. I also have a tiller attachment. My tractor already has a 48" belly mower that works very nice as a finish mower. I would love to make a front end loader or get one that would work for such a small tractor like mine 14HP total weight 885 Pounds. I found a cool web site but I don't know if I could tackle such a job. Front End Loader Plans
   / Fabrication of 3 Point Hitch Photos #15
Thanks for sharing your project with us, I really enjoy seeing someone build something like this and have it turn out so well. Nice work!
I did a little more work tonight. Welded on an attachment for the check chains. As suggested by another yanmar owner.
I welded on a pulley hub for the pivot arm.
This worked out very nice. I will take the shaft to my machinist friend and he will cut a keyway out for me. I also decided to weld on a smaller hub for the push arm pivot I will need to do that later this week. I should be able to test it out this weekend. I also put a coat of paint on the finished parts. Black color.
   / Fabrication of 3 Point Hitch Photos #18
Super nice work.
Have you adeed grease fittings for areas that are bushed / rotate?
What will be the lifting force? a smal sa cyl and a spool to tap it off the tractors hyds? or a ready power unit?
thanks for shareing.
Soundguy
Good idea I will add some zerks to make it operate smoothly.
I don't know what the lifting force will be I will have to try it out. It uses the exsisting ram that has a push rod attached to it. The hydraulic ram raises the belly mower deck now and can also raise/lower the 3 Pt hitch.
I gave the lift arm rod to my friend so he can cut some keyways for me. I have also painted most of the parts. I have also been dismantling the tractor so I can paint it. I just sanded and repainted the rear frame and axles of the tractor which had some rust spots on it.
2020 CATERPILLAR 299D3 SKID STEER (A52709)
2020 CATERPILLAR...
2016 Snorkel S4732 Scissor Lift (A57453)
2016 Snorkel S4732...
2016 International DuraStar 4300 S/A Cab and Chassis Truck (A56858)
2016 International...
2019 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2019 INTERNATIONAL...
WIGGINS 5K FORKLIFT (A58216)
WIGGINS 5K...
2025 BK56 Backhoe Skid Steer Attachment (A56857)
2025 BK56 Backhoe...
