JD 1050 problem with bucket - doesn't stay firm, flips up
   / JD 1050 problem with bucket - doesn't stay firm, flips up #1
farmer marx
Member
brattleboro VT
deere la105
Symptom 1: with the bucket flat down, 1 inch from the ground, if i try to get under a pile of snow or sand, the bucket will start lifting upward. I cannot get it to stay flat.
Symptom 2: let's say I raise the loader half way and I flip the bucket downward all the way. The goal is to 'cut' a pile of snow and drag it going backward. As soon as the bucket meets some resistance, I can't push the loader further down. Then, when I start driving in reverse, the bucket flips upwards.
Symptom 3: lift the loader all the way, flip the bucket 90% of the way down. The bucket dangles, it doesn't stay fixed in that position. HOWEVER, if I flip the bucket all the way downward, at that point it locks in that position, and if I lower the loader all the way to the ground, at that point I can lift up the front wheels.
A friend says it could be the pins. Another one says it's the hydraulics. What do you think, and in case it's the hydraulics, which components need replacing?
Thank you very much for your advice.
   / JD 1050 problem with bucket - doesn't stay firm, flips up #2
I was having somewhat of a similar issue but havent been able to confirm it yet.
Wondering if you are doing the same as what I was doing regenerative valve to kick in.
If its not that then it could be hydraulic cylinder seal repair time. :(
   / JD 1050 problem with bucket - doesn't stay firm, flips up #3
I think bucket cylinder piston retaining nut is loose or bucket cyl piston seal has failed
   / JD 1050 problem with bucket - doesn't stay firm, flips up #4
I had a 1050 for many years and never experienced what you describe. I agree with Jim, I think it's a problem with one or both bucket cylinders. I would test the cylinders by raising the loader boom about midway of its travel and curl the bucket either all the way up or down. Drive the tractor up against something solid like a tree until the bucket just contacts it. Put the transmission in neutral and uncurl the bucket. It should have enough power to push the machine backwards. If it moves it, lightly push the brake pedal to give some resistance and see if it continues to move. Try this again with bucket in the opposite position. If it fails this test I would rebuild both bucket cylinders.
   / JD 1050 problem with bucket - doesn't stay firm, flips up #5
Once you get it fixed, I’d go easy on back-dragging with the bucket curled all the way down like you describe in symptoms #2. There’s a lot of leverage doing that, it’s an easy way to bend the cylinders or blow their seals when something has to give.
Thank you. I read the entire post and replies and I think my problem is different, although it also involves the functioning of the bucket and loader. I learned a lot, especially about regen valves (I had no idea that their purpose was.)
Thank you. I will start there. I hope the problem is limited to the seal and the cylinder is not bent and doesn't require rebuilding/replacing. Somone replied that curling the bucket all the way down and scraping the ground puts a lot of pressure on the system and can damage it. I will try avoid doing that in the future. Unfortunately the problems were already there when I bought the tractor but I didn't know.
Thank you for the advice. Right now back-dragging with the bucket curled down is the only way I can get any kind of action moving loose material, dirt, sand, snow, anything. I hope I didn't bend the cylinders.
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
207274 (A52708)
207274 (A52708)
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
2019 Chevrolet Tahoe SUV (A59231)
2019 Chevrolet...
1454 (A57192)
1454 (A57192)
