/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #841
Hope not too much damage Dale. Sometimes we need to walk away and come back later to make things work, I know I get a little too focused sometimes.
Well twice yesterday within a 15 minute time period I manage to tip over my 500-600 pound ballast weight... Yes twice and even managed to get one pin wedged into quick hitch and missed other pin and top hook.... Sure glad I had added lift ring in top of weigh when I made it.... Well its upright for now and not where I want it but yesterday was along day and it did not end well..... Moral of dilemma, if making ballast weight put a lift ring on top, and be sure FEL can actually lift it if you are in recovery mode.....
Part of today will be spent assessing damage and repairs (if any)....
Dale
Well that really sucks !
Hope you did not do any damage.
I am lucky that I have enough room in my garage with a concrete floor to store my snowblower, dozer blade, front quick hitch, and my ballast box.
I have a HF 1 ton chain hoist installed spanning a few trusses with a 4" x 4" wooden post and each item is sitting on a HF 4 wheel dolly.
I just need to sweep the floor first before moving a dolly in place.
All my other implements are stored in a poll barn type garage with a gravel floor.
KC
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #843
Looked thing over today and only damage was where the ABS tubing used as vertical tool holder (1 of 4) got a little broken...Probable cut it flush with concrete and call it good....
Dale
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #844
Was doing a total service on the blower between storms and noticed the hydraulic fluid was a bit low in the tractor's sight glass. Looked around for the partial jug of hydraulic fluid I knew was around... didn't see it... Ah! There it is. Proceeded to put about 4 tablespoons of.... USED DIESEL OIL into the flexible funnel before I woke up enough to stop. (Substitute your own version of some choice words here)
Cleaned out the funnel, looked AGAIN for my hydraulic fluid and continued to top off the level after I found the RIGHT jug.
MORAL: Make sure to label those old jugs that you use to put used oil into! The Tractor Supply Co. fluid I had comes in a black, opaque jug; couldn't see what was in it. Rats.
Hopefully no heavy damage (I'll be changing hydro. fluid this spring), but one benefit -- I can now actually see the fluid in the sight glass, as it's now a tad darker....
So-- do I get the "dummy of the week" award?
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #845
4 tbs = 2 oz. Well, I'm sure it will be ok till spring, but that would nag on me, personally. I would probably just not wait and change it now.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #846
HST probably holds about 4 gallons of hydraulic fluid, a few ounces of used diesel oil is probably not the end of the world...
Dale
NO !
This dummy thinks you have created an upgrade for our GC's, as it's now much easier to see the level of the fluids in the hydraulic sight glass.
KC
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #848
I believe diesel has lubricating properties as well-if anything it might help lower viscosity which is not a bad thing in the cold winter :) Also hope everything works out for you Dale.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #850
No, that was me.... At least it was from my 2005 Jetta TDI Wagon, which means a very expensive, all-synthetic, VW 505.01-rated oil. Nothin' but the best!
%22My Baby%22 4:5:09.JPG
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #851
Getting to use the debris forks today to clear brush. Going to have a big fire soon!
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #852
Been doing the debris fork thing for last 5-6 days clearing brush and burn piles....
Dale
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #853
Added a new implement to the arsenal.
From Titan. Well built, I did have an problem with one of the Ubolts having threads that were no good. Sent an email and got notice that they were shipping a new one within minutes.
I don't know much about farming, what am I looking at?
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #854
It’s a hiller, it’ll make your rows after tilling and hills them up.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #855
that this thing?
prob not gonna buy one this year but had been looking at something like this
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #856
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #857
Dale
Good looking fork. How long are those tines? Mine are about 21"
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #859
bought a woods rt48.30 tiller today. all gear drive with 3 year drive train warranty.
have to trim one half shaft on pto, dealer trimmed for me but forgot I had pats hitches installed so was too short. no biggie.
side note: uploading images here SO much easier now. awesome.
/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #860
I have a Woods tiller, I believe the same, RB48. It works VERY well, pulls fine with my 2310. Oops.. just looked in my sig below (tiller's stored & covered); guess I have a GT40. Same -- it works very well. Even though it's a 40, it's just wide enough to cover tire tracks.
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
1993 M149A2 400 Gallon Potable S/A Water Tank Trailer (A59228)
1993 M149A2 400...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2015 Ford Escape AWD SUV (A59231)
2015 Ford Escape...
