Heavy duty landscape rake?
/ Heavy duty landscape rake? #1
cold1313
Gold Member
Northern, Ohio
Kubota M4D-071 Kubota F3990
Any suggestions? EA is about 16 weeks out and I need something before then. New or used!
/ Heavy duty landscape rake? #2
EA. Time will pass, quality won't.
/ Heavy duty landscape rake? #3
Woods makes a high quality rake...
/ Heavy duty landscape rake? #4
Where are you located? I have a woods trp I think model 7500. Was my dads but he passed and I nor my mom will ever use it. Excellent condition located in Michigan.
I see it says you are in northern Ohio. Give me a pm.
/ Heavy duty landscape rake? #5
Are you sure it will do the job? They are best for use over prepared ground that has become rutted - like rodeo arenas and such. It sure would be nice if you could borrow one to see if it is what you want. Around here people often loan each other implements. Most fairgrounds have one or several and they use them a lot.
The one I use is a heavy duty 84"' with an angling rake, a flip down grader blade, end caps, and two trailing wheels adjustable for height. That makes it close to a $3000 implement - which seems crazy, but it turns out that you will want all of those features depending on just much manicuring you want to do when restoring a manicured dirt or gravel surface. It's a nice tool for the few jobs it can do, but it's not a very heavy duty tool for brush or rocks. Using it on anything rougher than prepared ground clogs it up and rocks would ruin it pretty quickly.
So far I see it as an implement really good for raking & surfacing corrals, pens, and riding/roping arena - and maybe driveways if not too rutted... but not much good for anything else.
But maybe I'm wrong about that and someone else has found another use for one. If so, I'd like to hear around it.
rScotty
/ Heavy duty landscape rake? #6
Check out Befco landscape rakes. I just received their 6' standard duty (rated to 65hp) rake. 3/8" and 1/2" steel is used on the frame and rake. Weight is about 250#, welds look good and has good paint. I haven't had the opportunity to use it yet so I can't comment on how well it will hold up. From my research, Befco has a good reputation for quality products that will last. Price was about $1050.
It is replacing a 25 year old light duty King Kutter LR rake that has done a good job of pushing up brush, shrubs, limbs and trees into a pile for burning or hauling away with the grapple. This new Befco LR will used the same way with very little dirt work.
/ Heavy duty landscape rake? #7
I have a York rake very similar except for the trailing wheels. It is very heavy duty.
rScotty
That is one concern I have. I had a lot of trees taken down over the winter with an excavator. Sticks, roots, etc sticking out of the ground. Would like to be able to get the worst of it up and out. The grapple on the excavator did a pretty good job, but leaves a lot to clean up before I could start to level out the ground to prepare for seeding.
Message sent.
/ Heavy duty landscape rake? #10
Check out York rake with drop down grader blade.
/ Heavy duty landscape rake? #11
You might want to would rent one to see if it's something you can use for this one job. If that works well and it's something you want to add to your arsenal for future use I would then order an EA rake. I think Tuffman Equipment has the rakes for rental.
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2012 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 GMC Sierra...
2021 Caterpillar 279D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
John Deere 825 6R Cultivator (A66408)
John Deere 825 6R...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A65643)
2012 INTERNATIONAL...
Front Tank Bracket (A64126)
Front Tank Bracket...
