Rebar supports in a slab
   / Rebar supports in a slab #71
That's a good way to save some dollars. I'm no expert but I always wondered if some designs/brands of the plastic chairs made a void or weak spot in the concrete.
What are you parking on your floor that requires the additional strength of rebar?
   / Rebar supports in a slab #72
Nothing, it is just something I have wondered about for a long time.
   / Rebar supports in a slab #73
Rebar in a properly prepared and poured homeowner concrete floor, is a major waste of time and money.
   / Rebar supports in a slab #74
100% disagree.
Rebar is the most cost effective method to keep your concrete together that works every time when the basics are followed.
   / Rebar supports in a slab #75
A properly designed slab (including foundation) properly placed and poured to design specs on top of properly compacted and or tested ground...is not going anywhere...control joints work...in many places in the country (void of earthquakes etc...) there is no reason to put rebar in a residential slab...like I said above...there are no forces that would/will cause controlled cracks from separating beyond the limits of fiber and or wire mesh reinforcing...
   / Rebar supports in a slab #76
100% disagree.
The exact steel company salesman pitch.
   / Rebar supports in a slab #77
I have read every one of these posts. I find it interesting but I never suspected it would generate this many posts.
   / Rebar supports in a slab #78
There is a wealth of misinformation floating around on proper concrete placement.
The American Concrete Institute is a good fact source.
   / Rebar supports in a slab #79
Check price of adding fiber to concrete instead of the rebar. Fiber stops cracks before they can grow much in length
   / Rebar supports in a slab #80
Yep....I have a 16,000 lb tractor and 7,000 lb bailer sitting in my tin shed and the concrete hasn't moved a bit.
200722 (A51247)
200722 (A51247)
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2019 GENERAC MLT6SK-HERC LIGHT PLANT / GENERATOR (A52706)
2019 GENERAC...
Honda Pioneer SXS700 4X4 Utility Cart (A55788)
Honda Pioneer...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
Year: 2000 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 120,822 Plate: Body Type: 4 (A55852)
Year: 2000 Make...
