First time plowing snow
/ First time plowing snow #1
Mallard1
Arkansas
John Deere 4320
Just like everyone else in much of the south we are covered in snow. We have 7 down now with 6-8 more coming today. I need to open the driveway up so my wife can get out Saturday. I have my 7 blade hooked up and my bucket on. Any tips or tricks to not screw up my gravel driveway or general advice. I have it cocked to a 45ー angle throwing it to the right for now. Haven稚 plowed any yet though, going to start tomorrow when it痴 all on the ground
/ First time plowing snow #2
If you have skid shoes for the plow use them to set your blade an inch or so above the ground so you will leave a layer above the gravel.
If no shoes, then same deal with the inch clearance but you will have to adjust the blade up or down if the ground is uneven.
/ First time plowing snow #3
You can use your bucket but keep it tilted up so the edge doesn't dig into the gravel. Also be careful not to run into something, like ledge, as your loader isn't designed for that kind of impact. A blade without shoes to keep it from digging in is going to dig you plenty of gravel unless the ground is frozen (which I doubt). Start off not being aggressive and as you get a feel for it then you can try to get closer to the gravel. You can also back drag with the loader to finish up. Just angle it at about 45 degrees and leave the loader in float.
/ First time plowing snow #4
Adjust your top link to its shortest length. This will bring the rake angle of the cutting edge of the blade closer to perpendicular to the driveway surface which effectively reduces the cutting rake angle like on a lathe tool. By approaching a zero degree rake angle you will be less likely to cut into the driveway surface.
Think of it like a straight razor... the flatter the blade is to your face, the more aggressively it will cut your whiskers. As you pivot the razor closer to 90 degrees the less cutting action will occur. If you continue to pivot the blade past perpendicular then all you are going to do is smear the shaving cream off your face like frosting a cake.
Thanks for the help, this blade is light but doesn稚 have skid shoes. I don稚 have any ledges or anything to worry about except trees. Right now we have 9in on the ground and supposed to keep snowing until tomorrow morning. It is a very powdery snow so far.
If I want to make two passes each way down the driveway do I start in the center and move out or do the outside then move the center over and then move it to the outside?
/ First time plowing snow #6
As mentioned, you can slightly tip the bucket front edge up to plow. I've been doing it for years. On the rear blade spin it 180 * so it won't dig in.
The way I set it up in my shop is with the blade frame square to the ground, so I can spin the blade and it will stay parallel to the floor. If I shorten the top link up I will need to adjust the side link to keep the blade parallel to the ground. I also have both lift arms setup so they will float in the slot to try and help keep it level.
Do I need to put any silicone spray or anything on the blade?
/ First time plowing snow #8
Another trick you can use is slit a section of PVC pipe & slip it over the cutting edge of your plow.
It will glide over the gravel & still remove the snow.
I have bolted a section of angle iron on for a more permanent solution.
/ First time plowing snow #9
All good advice given but most of be patient and take your time until you get the feel for it.
/ First time plowing snow #10
Plowing isn't terribly difficult but like a lot of things it takes a while to get good at it. All I'd suggest is tip your bucket up just a little so you don't spend the spring raking gravel back into your driveway. I mostly plow using a back blade as in my experience that can do less of a number on your gravel. Play with your 3ph as you go so you're not digging but just skimming the surface; maybe even stop and look now and then before you make a lot of work for yourself later. Enjoy it, you will maybe never have to do it again.
"If snow doesn't give you joy you will have less joy in your life but just as much snow."
/ First time plowing snow #11
if the snow is powdery as you say, turn the back blade around so that you’re dragging it in reverse. It won’t dig in that way. May take a few passes, but it’ll work.
/ First time plowing snow #12
This is how I plowed my drive before I paved it. Works great.
With my current plow setup (front and rear blades) I still push backwards with the rear blade when moving snow off the driveway edge... Just glides right over the grass.
/ First time plowing snow #13
Start on the high side of driveway. push to the side and come back the other way, pushing to the other side.
/ First time plowing snow #14
I think that a lot of us try to be too perfect when we're plowing snow. I always have to remind myself that it doesn't have to be absolutely flat with every piece of snow moved off the driveway. Just get it done - if that means leaving a bit of snow on the driveway and not tearing things up - then so be it! Damage to a driveway may not disappear as easily as snow melting. Best of luck!
Thanks for all the advice, we are up to 18in now so looking forward to pushing it around. Last time we got anything close to this was 2001 and it was around 14in.
/ First time plowing snow #16
You said it's powdery, so you may get by with using the back blade. My experience is 18" is too much for the back blade -- it piles up under the tractor. In that case the FEL is the choice, and that's very slow going as you can't push the snow off to the side while running. So it's push for a while, with the bucket down but clear of the ground, then turn off to the side off the driveway, then back up and go again. Then clean up with the back blade. Last time we had 18" it took me two days to do our quarter-mile driveway (I'm not into long days).
I致e got all day to get it cleared out and I believe my truck would make it the 200yds to the road if I had to. My wife doesn稚 have anywhere to go until Saturday and she can take my truck if she has to.
Next week temperatures are going to be in the mid 60s so it will for sure be gone by then.
/ First time plowing snow #18
When plowing snow with my rear (back) blade I let the “tilt” (not angle) function of the blade free-float so that blade follows the contours of the ground independent of the tractor rocking one way or another.
Otherwise, one side of the blade can dig into the ground while the other blade side raises up when the tractor tilts (rolls) left or right ahead of the blade.
Also, say you’re plowing a lane and trying to move 4 “blade widths” of snow to the left. With big snows or heavy snow sometimes you can’t just start on the right and roll the snow left onto the snow you need to move with the next pass. Example: With 18” of snow, on the third pass you’re trying to plow 54” worth of snow to the left. Doesn’t always work.
You have to think ahead about how many “pass worths” of snow you can move before you’ve combined too much. And where is that snow going.
Sometimes you might have to start on the (left) destination side, and clear those 4 “blade widths” individually. This might take (1+2+3+4=) 10 passes.
(Results may vary)
(Edit: Or as more simply said below: Start on edges. Work towards middle)
/ First time plowing snow #19
Best advice so far:
Shorten the top link so the blade doesn't sut in as much
Keep the plow elevated 1" 0r 2" so it doesn't scrape the gravel so much
Rotating the blade all the way around so is "backwards" will keep it from digging in but not sure how well that will work with 18" of snow
Which tractor will you be using?
My other thoughts
I would do the edges first (center last) because you don't want to make a big windrow and then have to plow that and another plow width over the edge
At 18" deep, I would elevate the plow 6" for my first pass just for the weight on the rear tires and traction (an easier pull)
Finally, if I know a big snow is coming and I'm around, I will plow a couple of times with smaller snow depths rather than wait till the storm has dumped a lot of snow and fight that.
/ First time plowing snow #20
This is a really good point. I occasionally get a little too obsessed with having a pure and perfectly clean driveway lane, when my vehicles and most visitors/deliveries could easily navigate a few clods of snow here and there. The end result is snow melt in March or April and I see rows of gravel pushed 2-4' out into my grass, ugh.
At least here in Michigan this year, the heavier and repeated snowfalls didn't start until the ground was nice and frozen, and some little snows had packed into my gravel. So I can scrape it hard at full speed to better throw the snow and be done quicker/cleaner.
UNUSED WOLVERINE TF1-66-4000G-66" PALLET FORKS (A62131)
UNUSED WOLVERINE...
2005 Sterling L7500 Fuel and Lube Truck, VIN # 2FZHATDC95AV42993 (A61165)
2005 Sterling...
UNUSED KUBOTA MX1718 BRUSH GUARD (A62130)
UNUSED KUBOTA...
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A61568)
2002 Freightliner...
UNUSED CFG INDUSTRIAL MX15RX MINI EXCAVATOR (A62130)
UNUSED CFG...
Kubota M6060 Tractor (A61166)
Kubota M6060...
