Get your woolleys warming.
   / Get your woolleys warming. #81
6 degrees here this morning and light snow. Yes it is accumulating. The Big stuff is predicted for tomorrow, then down in the deep freeze. Supposed to be -8. And to us down here in pineapple land, that is really really cold. I went out yesterday as the ice cap had mostly sublimed off with the sunshine we had, I used the 4 wheel drive and had no trouble in the lane and the road where the county had treated them were dry. But I am glad this coming event will be a snow event not an ice storm like we often get.
   / Get your woolleys warming. #83
Its warmed up to -16F with 15mph wind. -38F wind chill. Might shovel the driveway if it gets to +50 today.
If the gas cylinders on you car's hood don't hold the hood up ... it might be cold.
Went out to get firewood from the garage (where I put it temporarily to keep it from being buried under snow) and realized I hadn't attached the battery charger to one car when I got back the other day. I drive so rarely that I need trickle chargers on both of them. Went to do that and raised the hood, only to find it wouldn't stay up without a makeshift prop rod.
   / Get your woolleys warming. #85
0 degrees today. Wind chill -16. 5 or 6 inches of snow on the ground, More coming down, and much more expected over the next couple of days. Supposed to be in the negative digits overnight, with wind chills maybe -20 or lower. Folks that is getting really really cold for us pineapple growers here in the "south".
10 or so with a stiff NNW wind and the little wood stove is maintaining about 60 inside.
   / Get your woolleys warming. #88
was 14 below last night.
luckly its been sunny, the greenhouse is doing ok. my 12 drums of water freeze a bit at night and are unfrozen by the next afternoon.
nearly all of my crews across tx, ok, nm, co have shut down for weather, my crew in north Dakota just takes it in stride. ha.
   / Get your woolleys warming. #89
"We anticipate we will need to continue these controlled outages for the rest of today and perhaps all day tomorrow," he said.
14 states face blackouts over power grid emergency amid winter storm
Time to shake the snow off the solar cells and get a hammer to get ice off the wind generation blades.
was time I worked for communication co and the M/W dishes would fill with snow so no signal . had installed heaters to heat and melt but only a cone did and still required the hammer to break up the ice slide off.
Texas news that power outages and the nation's largest fuel-producing plant are offline.
Going to clean the lint out of the billfold before this is over.
ken
2019 Ford F-450 4x4 Crew Cab and Chassis Truck (A49461)
2019 Ford F-450...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2015 Ford F-450 Knapheide Service Truck (A48081)
2015 Ford F-450...
2019 Ford F-550 Knapheide Service Truck (A48081)
2019 Ford F-550...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
