SmallChange
- Joined
- Apr 19, 2019
- Messages
- 775
- Tractor
- New Holland WM25 with 200LC front end loader, filled R4 tires 43X16.00-20 and 25X8.50-14 (had a Kubota B6200D with dozer and R1 tires)
Hi all, I hope this isn't too much of a tangent from tractors, but -- I just ordered a $180 Wen bandsaw for my shop and want to get some blades, and wondered what you would recommend. My usage is a light variety of work with aluminum, steel, plastic, and wood. Typically I'd be cutting out small parts, or parting stock such as: low grade steel threaded rod, aluminum extrusions, light steel angles (the perforated build-it-yourself stuff), PVC such as 3/8" thick sheet, and plywood for making little things like shelf gussets. I don't picture ripping long things against a guide, not often at least. One of the heaviest things I've cut in a while is the 3/8" by 2" mild steel bar I used to clamp my canopy to the roll bar. I'm not making furniture, here, the wood is for utilitarian unfinished items.
I'm thinking 2 or 3 tooth spacings, for harder versus softer materials, and to keep a reasonable number of teeth in contact with a given piece of work. My saw will take 1/8" to 3/8" blades, so I'm also thinking 3/8" for general purpose cutoff as well as less curvy cuts, and also the more delicate 1/8" just for the more curvy cuts. I'd maybe leave a moderate 3/8" blade mounted, as I imagine 3/8" would be more durable and cut straighter for those jobs where curves aren't needed. But, I don't know, I might always choose the best blade for each job.
I also have a chance to get an old Craftsman 3-wheel saw, more or less for free. I might get that and put it out in the barn with a coarse blade, and let that be my go-to saw for wood, and use the new one primarily for metals.
I'm a believer that power tools work way better if you have fresh blades, bits, or other interchangeable contact items, and choose them thoughtfully.
Thank you experts!
Thank you experts!
