2810 HST
/ 2810 HST #1
wilton
High,medium,low speed lever stuck in low position, cannot move lever. Is it repairable by me or do I need to get a mechanic to repair?
/ 2810 HST #2
How old is the tractor? How many hours? Have you check fluid for the HST?
Does it move when in low?
Does the steering work correctly?
Another question can you engage and disengage the PTO?
/ 2810 HST #3
:welcome: to TBN.
If you have front loader put down pressure on it enough to lift front tire than of the ground.
Try going forward or backwards couple inches or so than try shifting.
From the shifting leveler to transmission check mechanical joints for debris build up...maybe lube spray.
/ 2810 HST
Thanks for responding so quickly. Sorry I misinformed you about the model. It is a 2310 HST 4WD. 292.6 hours, new in 2004, oil level at rear sight glass above the low level mark. I bought it last year from a neighbor who bought it new and had it service regularly from a local dealer who is now out of business. I have not used the PTO yet but the power steering and hydraulics work fine it works fine in the low range but cannot upshift it into the higher ranges. When I first bought it I was able to change ranges. Also having a few issues with start-up and shut down. I use the manual fuel shutoff.
/ 2810 HST #5
The model makes a different in troubleshooting your problem. Your tractor uses electro hydraulic clutch, knowing whether the PTO works would help. But I'd be looking at either a fuse or wiring problem in the clutch circuit. Also you might have a place to add fluid for the clutch. Had a Toyota and if fluid was low clutch won't work right. Plus the chance a bracket might have moved that mount the assembly.
Be sure and check to see if your low on fluid in the clutch, you probably have a spot to add like you would on cars.
/ 2810 HST #6
According to tractor data.com your 2310 was built by TYM. The range shifter is difficult to operate on my TYM built 2538 also, may just be the way they are designed. Try using the suggestion from Thomas about shifting while moving a little bit.
/ 2810 HST
Re: 2810 HST \
Went out a while ago and tried recommendations, still nothing changed. Checked fuses and they checked OK. Possible relay? PTO light lights up but neither PTO operate. Still cannot get lo-med -hi shifter to move. Thanks to all of you for your concern and recommendations!
/ 2810 HST #8
Are you keepinp it at idle when you try shifting? Also make sure it is in two wheel drive. Like mwayne i also have a 2538 and a 2810.
/ 2810 HST #9
Re: 2810 HST \
It also helps to lower the fel and 3 ptdown all the way .
/ 2810 HST #10
Problem with PTO is not linked to the transmission problem, I believe, since it uses a solenoid which is turned on by a button. Unless there's a voltage that both use. Does the solenoid energize, should be able to tell using a screwdriver next to it.
/ 2810 HST #11
Does your 2310 HST only have a brake and not a clutch. And you have to be completely stopped to change transmission from low or high position. Can't find much about it not even a owners manual from Mahindra. May have found a TYM manual just not sure of their numbers.
/ 2810 HST
Has 2 brake pedals left side, 1 pedal right side. I have all manuals and cannot find anything about the lo,med,hi shifter except in the schematics. 4 wheel drive not engaged, PTO's not engaged, rear axle interlock not engaged.
/ 2810 HST #13
If you send me a private email with phone number I'll give you a call.Might be easier over phone.
/ 2810 HST
OK folks, at 70 plus years I have a hard time getting on my hands and knees. So today I finally got out the creeper and crawled under and disconnected the shift lever from the transmission and found the pivot rod and lever was froze due to being rusted (welded like). I lubed it up real good and now the shifter seems to work fine. I only had to crawl under about 10 times plus to get the right tools and do the job. I want to thank all for their advice and troubleshooting and directing me to the answer.
/ 2810 HST #15
Glad you got it working, I guess that I was under the wrong impression that it had just stopped from being able to shift the transmission, didn't ask right question. But Thomas was right on with his posting.
/ 2810 HST #16
Glad it was easy fix. :thumbsup:
KENT HYDRAULIC HAMMER ATTACHMENT (A60736)
KENT HYDRAULIC...
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
2018 F550 Bucket Truck (A61307)
2018 F550 Bucket...
Honda UTV (A56859)
Honda UTV (A56859)
500BBL WHEELED...
2016 16ft. C and S Lawhon 2.5 Ton Pipe Top T/A Utility Trailer (A60352)
2016 16ft. C and S...
