Retaining walls and patio
   / Retaining walls and patio #161
Muhammad, maybe I missed it, but what are you compacting the base with? I don't see a compactor in these recent pics. I hope you're being OCD about compaction..... I know you don't have frost, but still.
We compacted the class 2 road base but the sand bed that the pavers lay on doesn't get compacted before the pavers go down. Instead we compact the pavers after everything is installed, and then again after the joints are filled with polymetric sand. That's the process the mfg recommended.
   / Retaining walls and patio #163
Ah ha! Thanks for the explanation.
   / Retaining walls and patio #164
BLUE WHALE INFESTED DIS THREAD!
Before you know it the patio will be done.
Not pictured: All of the tricky cuts are saved for last. IMG-20210203-WA0000.jpeg
   / Retaining walls and patio #166
Looks good. That shrub looks to be getting a hair cut on the backside?
   / Retaining walls and patio #169
Besides not making any sense..... who uses "infested" and "dis" in the same sentence. The two words don't fit into the same intelligence pattern.
(removed) adopted this creative way of writing somewhere along the line. If you search back on his early posts you will find normal writing. No harm, no foul I guess. Put him on ignore if it bothers you. He is actually a smart person if you read between the lines. Not worth fussing over. Back to retaining walls and patios. :thumbsup:
2014 BMW (A55758)
2014 BMW (A55758)
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A54865)
2008 IC...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
