Retaining walls and patio
   / Retaining walls and patio #161
Muhammad, maybe I missed it, but what are you compacting the base with? I don't see a compactor in these recent pics. I hope you're being OCD about compaction..... I know you don't have frost, but still.
We compacted the class 2 road base but the sand bed that the pavers lay on doesn't get compacted before the pavers go down. Instead we compact the pavers after everything is installed, and then again after the joints are filled with polymetric sand. That's the process the mfg recommended.
   / Retaining walls and patio #163
Ah ha! Thanks for the explanation.
   / Retaining walls and patio #164
BLUE WHALE INFESTED DIS THREAD!
Before you know it the patio will be done.
Not pictured: All of the tricky cuts are saved for last. IMG-20210203-WA0000.jpeg
   / Retaining walls and patio #166
Looks good. That shrub looks to be getting a hair cut on the backside?
   / Retaining walls and patio #169
Besides not making any sense..... who uses "infested" and "dis" in the same sentence. The two words don't fit into the same intelligence pattern.
(removed) adopted this creative way of writing somewhere along the line. If you search back on his early posts you will find normal writing. No harm, no foul I guess. Put him on ignore if it bothers you. He is actually a smart person if you read between the lines. Not worth fussing over. Back to retaining walls and patios. :thumbsup:
PSI 8 Cylinder Power Unit (A57149)
PSI 8 Cylinder...
2025 FUTURE X-DM43 SKID STEER DISC MULCHER (A58216)
2025 FUTURE X-DM43...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
2017 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52709)
2017 CATERPILLAR...
2009 SHOP MADE MARATHON 20KW GENERATOR TRAILER (A58216)
2009 SHOP MADE...
