New Holland 3pt issue
/ New Holland 3pt issue #1
WHMOBX
Dayton, Maryland
1954 Ford NAA, 2004 New Holland TC 45 DA
I need a little help with an issue I am having. My tractor is a '04 New Holland TC45DA. Late fall, when raising the 3 point hitch, all of a sudden it would go all the way up even though the handle was only moved a 1/4 of the way up at most. To lower it you have to quickly move the lever back down and back up a little to get it to stay at the desired height. I tried adjusting the drop rate valve per the manual but that did not correct the problem. I know it is due for a fluid and filter change and hope to get that done this weekend. Does anyone have any other ideas of what could be the problem??
Thanks,
Bill
/ New Holland 3pt issue #2
Thanks,
Bill
Is there any chance the linkage is jammed or bent?
Thanks, I will definitely check the linkage out although, the lever moves freely as it always has.
ATTENTION! PLEASE READ (A64127)
ATTENTION! PLEASE...
Johnson 3pt 12' High Speed Disc Harrow (A64119)
Johnson 3pt 12'...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
1999 Freightliner FL80 Altec A75 75ft. Bucket Truck (A61573)
1999 Freightliner...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
