Another "Underslung" Story
/ Another "Underslung" Story #1
senecak19
Western, MA
L3200HST
I thought I'd follow suit and post my Underslung Plow Build.
Reading threads about this, I found several other builds that were extremely helpful in planning my build. So before I begin with my post, I think itç—´ prudent to give credit to those folks here:
GORDONGOULD
https://www.tractorbynet.com/forums/...snow-plow.html
CHIM
TRACTORNH
https://www.tractorbynet.com/forums/build-yourself/401291-snow-plow-build-finished-underslung.html
A HUGE thank you to GordonGould and Chim (as their known on here) for helping me along the way and answering the dozens and dozens of questions I had.
Without further a due, here goes:
This was built around a Kubota L3200. I tried to be weight conscious because I picked up an older Fisher plow that weighed an absolute ton. As in, covered in snow and ice, three grown adults couldn稚 lift it into the back of a セ ton truck.
I intentionally shopped for a 7 or 7.5 plow figuring my L3200 would be pushed to its limits and an 8 would only make it worse. 7.5 seemed to be readily available and I was able to source this one with the cylinders, A-frame, push bar (albeit cut in half) and an almost new cutting edge for $100. I opted not to use the cylinders and purchased a new set of OEM Fisher cylinders locally out of fear of contaminating my tractor.
I took a risk and built this around a ï½¼ SSQA plate after reading one persons review that it would be sufficient. I did it because they were out of stock of the 5/16 plate that I wanted. I'm hoping with enough bracing, it'll be fine. More to come on that.
I really wanted to build GordonGouldç—´ design (vertical push members), but my little tractor had virtually no cylinder capacity remaining when in the vertical position. I contemplated this a long time and ultimately decided the weight savings would help me to go with one of the other persons designs and thus the forward leaning plate design it was.
The restrictors and Crossover valves and Flow Restrictors are a carbon copy of Gordonç—´. The 3rd function valve is a Landpride OEM kit. For anyone looking to purchase this, pay attention. There is three sets of install instructions and there all different! They indicate different end configurations. The kit today comes with a male/female ISO 7241 Series A connectors for the end of your machine. One set of instructions indicates two males, which my kit did NOT come with.
The A-Frame Paint is Magic paint from TSC simply because I had purchased a gallon of it a long time ago and had some left. After reading some of the fading threads, I wasn't thrilled, but in the end realized fading isn't an issue for me, I'm more concerned with its durability chip wise as I don't want a rust bucket laying around. The new frame member is primered because we just received 12" of snow and I didn't have time to get it painted, so that will have to wait until the spring.
I re-used the original push bar since mine was in decent shape (unlike Gordonç—´). After measuring it a few times and trying to figure out how to use it with good strength, I realized 2.5 box steel fits inside the i-beam perfectly. I just needed to cut the two factory gussets out. For reference and in order to maintain as much as strength as I could, I flipped the push bar upside down and cut the bottom gussets out (not the top ones). For whatever reason the bottom gussets were backing one of the plow pin mounts. Hard to explain. The top gusset supported both of the plow pin mounts. So, I kept the latter and cut the bottom ones out. Plates welded on the side and rear section of the frame connect the entire structure together. Also note, the box steel that extends forward to connect to the SSQA plate stick out past the rear section of the frame so I could add a rear gusset. Again, trying to maintain as much strength as I can.
I welded this up with as many gusset plates as I deemed appropriate. Just how I did it. Looking at other builds and some really cobb'd together projects out there, I'm going to hope I got this a touch on the overkill side as I hope to never have to fix it!
Today was my first go at using it and my initial impression is it's definitely quicker than a bucket. Simply put, you don't have to dump the bucket every pass and the angling of the blade allows you to push snow for the most part without stopping! We got close to 12 and I plowed three different substrates this morning: grass, pavement, stone driveway. The grass being frozen did quite well. Plow pushed the 12 without having to stop. The paved driveway was on a slope and transitions directly to the road which just sucks with anything. Naturally, the plow scraped it clean. The worst of the three was my own driveway. ¾ stone and the plow picks them up everywhere. They don't really freeze over so the drive looks clean, but stone in every pile I have. I'm not one to fuss about it though. I'll take the speed over a little bit of stone. I have intention of laying down some recycled asphalt in the spring anyways. That should freeze over and make plowing next year even better.
As simple as these builds look, there's real money involved. I knew this going into this and moved forward because 1) I wanted third function hydraulics for other attachments and 2) I intend on keeping my plow forever. I started plowing for neighbors and needed something to make the process quicker and easier as I have an 18-month old that I'd rather spend my time with. .
Cost to Build:
Third function valve: $800
Fab Steel: $100 (Does not include the large angle iron or random gusset plates)
Paint: $0
Plow Hydraulics: Cushion Valve, Flow Restrictors, Hoses, etc..: $265
Gallon of UDT2: $25
Bottle of Loctite 545: $18
Two Replacement Pins: $10
Angle Cylinders: $235
Plow Skids: $75
SSQA Plate: $111
Chain: $20
TOTAL: $1659
I'm sure I missed some cost somewhere. Consumables such as argon mix got me. Just when that ran out, my weld wire ran out as well. Bwahh! I'm sure if I added it all up, I could get close to a dead even $2000 for this project.
Hope this helps some of you. Happy plowing!
The build took me a little while longer as I spent time researching a good method to wire in lights and 3rd function valve. In the end, I wired in a relay with a new fuse block just to the side of the battery. Fab'd a bracket to hold the two so it doesn't interfere with the hood.
/ Another "Underslung" Story #3
That's some impressive fabrication. I just wonder if it would have been as easy to do a frame mount and not use the loader?
A few more photos.
Thank you Kenny. I'm far from an expert on "plowing". If I sourced a smaller (lighter plow) I could've considered a frame mount. I won't lie though, the research required to do what I did was readily available on here and I came across it and never contemplated a frame mount build.
/ Another "Underslung" Story #5
Nice work! - and you finished it just in time.
Thank you Chim!
I'm going to reiterate A HUGE THANK YOU to you Chim and Gordon! This project was outside my hydraulic/plowing knowledge base and I couldn't have done this without your help!
Here's the complete rig. The plow being as heavy as it is, I'm happy to have the Carryall on the back as it's heavier than it looks and provides just enough ballast. Helps when I put the snowblower in it too to clean up my elderly neighbors walkways :)
/ Another "Underslung" Story #8
Tickled that everything worked out well for you! I probably already mentioned the Ty-rap "whiskers" on magnets that I use for repeatable adjustments on my plow but here goes. Most of the time I float the blade and A-frame only and not the loader arms. To get the A-frame level and parallel with the ground, I set up on a flat surface and adjust the curl/dump and up/down and get slack in the chains.
When it's where it needs to be I stick the magnets on the loader arms so there's a quick reference for each. For the curl/dump it's the end of the rod of the level indicator. For up/down it's a bar on the grill guard. Having used this setup for a while, it's pretty natural to give them a glance each time I drop the blade. It's a lot easier and more accurate than trying to see the blade itself. Others here have done similar things.
/ Another "Underslung" Story #9
Good job on the plow build Kevin !! Very good write-up too. With a tractor your size getting the blade back closer to the tractor makes a world of difference when it comes to steering and weight distribution. I think you will like using it.
For me one of the big advantages of a floating plow on the loader arms vs a plow mounted on the frame is the ability to stack snow in high piles. I can easily push up 10' and higher piles so I can get rid of a lot of snow and stack it in a small area. Another advantage is being able to back drag with down pressure. With a design like Kevin's you can float the blade on the chain or apply down pressure
with the loader arm weight or hydraulic down pressure. Very versatile.
But you need an easy way to reset the plow frame level to the road surface after doing some stacking or back dragging. I thought Chim's magnet idea was a genius solution for the loader arms and the bucket level indicator works for the curl/dump setting.
gg
Thank you Chim. I do have the photos of your magnet setup and will look for one at HF the next time I drive by.
GG - Looks like I have my first modification is forth coming. Since I wasn't able to mock this up much, I didn't realize the plow frame due to the design I built sits directly over the cylinders. Trying to apply down force with the loader is consequently applying force to the cylinders, which can't happen. Looks like I'll be adding some 1/2" plates to the bottom of the fabricated frame to allow the primered frame section to apply pressure to the orange A-frame and NOT the cylinders. Will be a quick fix and won't stop me from using it in the interim.
I know most of you beat read this forum section end to end. But in the interest of keeping my story board together for future people searching, I'm going to include my test video here as well. Surely nobody will find it on page 608 of the other thread. :)
Underslung Plow - Test Run - YouTube
Might as well keep this thread going. After looking everything over and considering various scenarios, I realized I had a problem with my design. Comparing my build to CHIM's it quickly became apparent, his ability to apply down pressure was almost a must have. Everyone has a need to back drag once in a while. When I checked my dimensions, I quickly realized, my plow frame was applying down pressure via the cylinders, which obviously cannot happen. I also have a need to maintain as much float as possible in my plow setup due to an incline driveway I plow. After staring at it for a few minutes and contemplating Chim's design, I went another route. We'll see how it goes. So far it seems full proof, but time will tell.
Here's a photo of the fix. The lower angle iron was added. That comes into contact with the A-Frame, long before touching the cylinders. I also haven't lost much float as I've only lost the thickness of the angle iron (1/4"). I didn't weld it completely as it's not really doing much. Maybe I will in the spring. Who knows???
/ Another "Underslung" Story #12
Nice work! I am collecting parts to do the same thing. Have the 5/16 SSQA plate and the plow. Need to collect hydraulic parts and some steel to fab with.
Did you use 2.5 square tube for the 殿rms from SSQA plate to the push beam?
I have been trying to determine what to pick up for steel without having to buy a lot of different things.
Sorry for the late response. Somehow I shut off my email notifications and can’t figure out how to turn them back on!
I used 2.5”x0.250 for everything that looks square.
How much steel are you missing? I ask because I have a purchased more than I needed and would part ways with it if you don’t want to buy full lengths. I also have 29” of the large angle iron leftover too which is enough to copy my build. I ask because your not far from me!
