Buying Advice Mahindra 6065 4WD
/ Mahindra 6065 4WD #1
MUDONTHETIRES
Gold Member
Northern Louisiana
Mahindra 6065 4WD
So, I'm looking at a new 6065 4WD and wanted to know your thoughts. Any reason to stay away from this model? All opinions welcome and thanks in advance! I posted this on the Mahindra page with no luck. Was wandering if anyone has any insight as to go for it or stay away.
/ Mahindra 6065 4WD #2
I guess if you like the Mahindra tractor and want a bigger one I don't see a problem or do you want 2 tractors?.........
/ Mahindra 6065 4WD
My 4530 is no longer functional, it is scrapped so the 6065 will be my only tractor.
/ Mahindra 6065 4WD
also relevant imo, how'd it die.
It was a 2007. Had it serviced by a local tractor mechanic. He found two seals leaking and took off some under belly armor to try and get to the leaks. Couldn’t get to them without having it brought in to his garage (not leaking bad) so I told him I would have it delivered but wanted to bush hog first. He failed to reinstall the tow bar frame pins before he left and ten minutes into bush hogging the bar that holds the tow bar frame to the frame came out because it didn’t have the pins in. The tow bar frame flipped under the tractor then up behind the tractor hitting my pto shaft and ripping the tranny out. Mahindra dealer estimated 8K to 10K damage. Sold it at the auction for 4K to recoup some of my money. So here I am needing a tractor which is the reason for my question about the 6065.
BTW....... my first Mahindra was a
2WD and I loved everything about it. Decided to get a 4WD and had no issues with it and also loved everything about it as well. It was not the tractors fault what happened but a mechanics mistake. I’ve had great luck with Mahindra and want to go with another one.
/ Mahindra 6065 4WD #7
I have 2 mahindra tractors and like them both , One has over 1100 hrs the other 360 or so with no issues, The 6065 looks to be a beast of a tractor , Keep us updated.
/ Mahindra 6065 4WD
Thank you so much!
/ Mahindra 6065 4WD #9
Sorry about the tractor. If you can make a good deal on the new one buy it..Good luck..
/ Mahindra 6065 4WD #10
Thanks for the explanation, as a newer Mahindra owner, I'm happy to hear that if it didn't have an accident it would still be kicking. I've been very happy with mine.
/ Mahindra 6065 4WD
It was in great condition other than the small leaks. That’s why I’m going with Mahindra again. Thanks for your input!
/ Mahindra 6065 4WD #13
l have no experience with Mahindra. What interested you initially? And what are the features you like? Thanks.
/ Mahindra 6065 4WD
What interested me was the total weight, lifting capabilities and reviews from other owners.
/ Mahindra 6065 4WD #15
I have a 03 3510 and a 2014 8560. Both are good tractors and I am happy with them.
John Deere 1025R Tractor (A61166)
John Deere 1025R...
2016 Chevrolet Cruze Sedan (A61569)
2016 Chevrolet...
UNUSED LANDHERO LDH-LB9510 LEAF BLOWER (A62131)
UNUSED LANDHERO...
2011 Chevrolet Cruze Passenger Car, VIN # 1G1PK5S94B7295110 (A61165)
2011 Chevrolet...
2012 Dodge Charger Sedan (A61569)
2012 Dodge Charger...
2025 Grapple Hydraulic Mini Skid Steer Attachment (A61567)
2025 Grapple...
